    New icons
    21 Posts 7 Posters 3.8k Views 7 Watching
      Daniel S
      Thank you Ibon!
      They are great 😍 😍
      Daniel S
      • ibonI
        ibon
        Ok, watkins. Here are in .zip
        New Bezier Icons.zip
        Surface Tools.zip
        • fredo6F
          Ibon,
          Your icons are great, I like the design.
          Could you however make them a little big bigger so that they cover the samll button surface. In Sketchup with 'small' buttons, we do not see enough of the details.
          Also, if not too much asking, I would need the cursors (also as png in 32x32) for the cursors, as they are supposed to be inspired from the icons.
          With your permission, I think of adopting the icons and package them in a next version.
          Thanks very much
          • ibonI
            ibon
            Fredo6, It would be an honour for me of course. But there's one thing i don't understand:
            When I made the icons i set their resolution at 24x24, because if it was bigger, when i open sketchup they look worse. So if you have "small icons" mode in sketchup won't be more logic to have smaller icons instead of bigger (32x32). It's only a question, I don't know how it works.
            And well, to make icons i made a sketchup model, exported image, opened it in PS, put out their background and resized them to 24x24. The i erased the sketchup model. So i dont have the original skp file, i cant make then bigger (only with PS). I'm so sorry, i didn't know anyone would like them 😞
            • fredo6F
              Ibon,
              Actually, this is not the size in absolute pixels that matters, but the fact that you use the full square area. I guess you could just scale up a little bit the drawings, to use more real-estate in the square. In this way, we can distinguish the circle from the polygon, which otherwise are quite small.
              For the question of big vs. small icons, I made provision in the code of Tools On Surface (and Round Edge) for icons to be specified both in 16x16 or 24x24.
              The naming convention is that the plugins accepts 3 file names, for instance:
              The script will look first for the most relevant one if it exists, and otherwise try the other filenames.
              In the current version, I was lazy and just design icons in 32x32 to go to the small and big toolbar modes (my opensource icon editor does not support 24x24 and 16x16).
              Again thanks for your initiative
              • ibonI
                ibon
                Fredo, i made the icons only for me and that was the only reason i didn't ask permission to you. But if you want i would be glad to make again all the icons and asociated cursors. if you plan to include them in your next release i will work whatever is necesary until i achieve the best result. this time i would send you them instead of posting, and you will decide if they're apropiate or not.
                I end my exams at 23 june, so after that i will start working on them. Of course, only if you want. Only tell me, and thanks again 😄
                • fredo6F
                  Ibon,
                  Take your time, Tools on Surface is still a quite long story (and requires many more icons and cursors).
                  Just to be sure I was clear by 'scale up' is simply to use the maximum space in the button, as in the following sample:
                  Thanks in advance
                  PS for Daniel S: your icons were not bad too, and actually very much in the style of Sketchup, with the brown color.
                    Daniel S
                    For me the Ibon icons look really good and much better of what I can make.. but I believe that the icons will look better with a brown color on surfaces too. Is something that can be easily changed.
                    Offtopic, but today using tools on surface I thought that a "scale on surface" would be useful. Not making a request because you have already too many things but I´m telling this because something like that can replace some other future tools. For example, using the circle OS and then using the Scale OS you can make the Ellipse OnS, or with the poligon OS you can make a square and then with the Scale OS make the rectangle OnS. Just a thought 😕 ...
                    Daniel S
                    • plot-parisP
                      plot-paris
                      I agree with you, Daniel S. the wonderful icons look even better with a brown colour (thus blending in to the overal SU icon style).
                      good luck for your examns, ibon. 👍 I am looking forward to your new creation...
                      "ScaleOnSurface" - what a wonderful idea! I am confident eventually fredo6 will succeed in including inferrences into his marvellous toolset though (so that the rectangle tool will signal, wenn being a square/golden section, and we don't need the scale tool for that anymore).
                      fredo6, the wishlist for you gets longer and longer... but every time you check off a point on it, hundrets of SU freaks have tears of joy in their eyes! I haven't had that many birthdays a year in my whole life! 😄
                      • fredo6F
                        Daniel S
                        Actually, my plan is simply to release a Polygon tool specified by 3 points, which will cover ellipse (with high number of segments), down to rectangle (4 segments) and isocele triangle (3 segments).
                        Otherwise, the only idea I could see for Scale On Surface, would be to force the Offset in a particular direction, or in radial mode, from a particular point. In the general case, I think you have a better control with the Offset tool.
                        • plot-parisP
                          plot-paris
                          but "Scale" would be one of the last tools to add - for having the one "OnSurface" button! 😄
                          we have allready:
                          • line
                          • circle
                          • polygon
                          • offset
                          • push/pull (joint push pull tool)
                          now its only left:
                          • rectangle (which already exists with the polygon tool)
                          • arc
                          • freehand
                          • move
                          • rotate
                          • scale (which is indeed an offset with contoll in two directions)
                          • follow me (???)
                          then we still can use ibon's buttons (if you press the one, the great, the wonderful OnSurface button, all above tools change their icon). 😍
                          sorry, just dreaming. got a bit carried away 😳
                            Daniel S
                            I must admit that the idea of a scale on surface sounds strange.
                            The idea was to quickly change a draw on surface like a move OnS can easily change the position of the draw OnS.
                            SU make this very well on planar faces... but in curved faces is very bad.
                            I attach images only to explain and clarify what i tried to say.
                            Daniel S
                            SU results
                            scaleonsurface
                            • david_hD
                              david_h
                              Where do we place them so we see them on the toolbar?
                              D
                              • ibonI
                                ibon
                                You have to put bezier ones into your
                                .../Plugins/BZ_Dir folder, and surface tools ones in
                                .../Plugins/TOS_Dir folder overriding
