    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 171.8k Views 83 Watching
      mateo soletic
      Fredo,
      Thank You very much.
      Concept Illustrations
      • jujuJ Offline
        juju
        Nice! Thanks!
          STRANGEZOND
          Thanks! Very useful!
            dtrarch
            Hi Fredo
            I thought this would never show up.
            Simply amazing and thank you so very much.
            dtr
            • boofredlayB Offline
              boofredlay
              Thank you!
              • urgenU Offline
                urgen
                ...CO-O-O-O-O-O-O-O-O-O-O-O-OL! πŸ‘ πŸŽ‰ πŸ˜„
                http://img181.imageshack.us/img181/2699/100lr0.jpg
                http://img181.imageshack.us/img181/3900/101vl6.jpg
                100.skp
                --pupil forever...------
                  A cousin of TopMod? πŸ˜‰
                  • urgenU Offline
                    urgen
                    ...standart shape (components)+Round Edge - v1.0 ...delete some faces πŸ˜‰ πŸ˜„
                    • StinkieS Offline
                      Stinkie
                      Thank you! Very cool.
                        breezmisha
                        (= all try not wait! thanks great! 😍
                          Ben Ritter
                          Fredo,
                          Thank you very much.
                            cnicolapc
                            • fredo6F Offline
                              @kmead said:
                              I do have a quibble which may or may not be shared by all:
                              The intersection of the rounded edges should meet in a semi-spherical intersection when three arcs meet at a corner, versus the hipped or groined intersection that is now occurring.
                              I think it would be manageable to make a 'polished, round' join for 3 edges, whatever is their orientation. It's probably a geometrical headache, but the method would be mathematically exact, and imply no surface intersection.
                              This is simply based on the remark that if the 3 edges are mutually orthogonal, as in a cube, you can draw a spherical join. Then, because you can always transform geometrically 3 edges with any orientations into orthogonal axes (via 3 plane shear transformations), you could deform the join as well with these transformations. This would give a junction with no groined intersection. This would work for 2 edges too.
                              For 4 edges or more, I am not sure there is a geometrical shear transformation, preserving parallels, that could allow to transform them into a regular topology. But maybe I am wrong!
                              Anyway, this is just for future work, but it's an interesting idea to explore.
                                ScottPara
                                I tried the ruby and I am impressed just in the time savings involved. My question is why is it still making hard corners? The far cube is from the script the closest one is using the longer method of rounding the profile the extruding and then rounding the top and bottom flats. Am I missing something, as I thought this is what the result I would have got fromt he script.
                                Scott
                                Love the fact that some HATE my avatar.....
                                • fredo6F Offline
                                  As said in my previous post, I need to check if it's manageable when edges have any orientation (I think it is), and also confirm that it only works for intersection of 2 or 3 edges only, not more.
                                  Note also that the 'true' rounding generate much more faces at the corners.
                                  The initial version was more a trial and is closer to the spirit of a FollowMe. The interest, in my mind, is that it should be capable to handle custom profiles, allowing to decorate edges with profiled shapes. It also helped me to check how Sketchup handles surface intersections (which you can see is not always perfect, due to precision problems).
                                  So, don't worry, I keep the request in my list.
                                    ScottPara
                                    Thanks Fredo!
                                      marne
                                      Wow! Thanks for this great plugin! This is a true little helper. πŸ˜„
                                      • I Offline
                                        ilay7k
                                        how many editions of sketchup 7 are...one of is Fredo6Up πŸ˜‰
                                        Thank you for this Tool!
                                        • I Offline
                                          Iglesias
                                          Thanks a lot Fredo
                                            alphaonerecon
                                            Hello
                                            I'm new to SketchUp and just installed the bezier plug-in.
                                            I am having drastically different results from everyone here so I
                                            am clearly doing something wrong.
                                            I followed the instructions, which are pretty straightforward, correctly but seem to be
                                            missing something.
                                            I have enclosed before and after pics of a simple box I attempted to round the corners
                                            on.
                                            When I applied the tool, this is what happened as a result.
                                            I'm assuming it may have something to do with the pref' box that pops up once the tool is used?
                                            Is the rounding automatic? Do I have to input data for it to work?
                                            Please help this newbie!
                                            Thanks! 😳
                                            before
                                            after
                                            • 2 / 9
