    Render #22 (animation test bottom page 8)
    120 Posts 30 Posters 18.8k Views 30 Watching
      Jackson
      I love the texturing on this building- especially the concrete structure underneath- it looks weathered- nice work!
      Jackson
        Jorgensen
        Look great.
        Typical - give you a new toy and you come up with some magic stuff 😄
        I'm a great fan of your work. All your renders have somekind of magical touch. Can you reveal some of secrets ? (like post processing in PS 😄 )
          princedragoncok
          Likewise, i'm a big fan of your work. Always looking forward to your next render
            kwistenbiebel
            Thank you. That's too kind.
              remus
              I tihnk i prefer the vray one, looks a bit more lively somehow, i thik t might be the sky...
              Slight crit as well in the texture mapping on the window frames, i reckon itd be improved if you just mappedsome straight grain textures on to it, or even the same texture yu used for the main building, just not projected on, kinda spoils the look a bit for me, although im just nit-picking really 😛
                kwistenbiebel
                I understand.
                I wanted to make the upper body as 'mono-material' possible though, but I agree the frames could have used a different texture projection/scale.
                  lapx
                  THIS IS REALLY NICE DUDE 😎 I will have to buy this program FFD 😍
                  Ok, I meant subdivide 😳
                    lapx
                    kwist, I'm a fan of your work also.
                    You seem to nail the texture and color combo everytime. Your forms are nice too.
                    Good work.
                      kwistenbiebel
                      Re-rendering the still view in Vray:
                      (to see full view without cropped right side: right click and..)
                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/Projctview1jpg-small.jpg
                      • I Offline
                        igor
                        i, like remus, like the v-ray render over the originals. i think the reason it looks "lively-er" is because it's brighter. the other ones always seemed a little dark, so seeing this had a big contrast. keep it up kwist!
                        The genius switch has no "off" position
                        Intelegence is natrual, it takes real effort to be ignorant
                          kwistenbiebel
                          Ok, the 'full' animation is finished
                          Watch it only when you have enough bandwidth...
                          I hope you guys like it 😛 :
                          [flash=800,641:35mofg0q]http://www.vimeo.com/moogaloop.swf?clip_id=1133153&server=www.vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:35mofg0q]
                          link to full screen version:
                          And a Youtube link:http://www.youtube.com/watch?v=03i-opUVaMk
                          • chavinskeeC Offline
                            chavinskee
                            wow!!! awesome work as usual! and now using vray. care to share the visopts. been trying my hand also in vray but nothing comes cloese to your work. keep 'em coming! you inspire us to do better!
                            http://chavinskee.blogspot.com/
                              princedragoncok
                              How long did the v-ray render take? It is clearly better than the other renders and I'm tempted to give vray a go. Just a quick question though; how steep is the learning curve? would it be comparable to indigo or are we talking much harder? And just finally, why don't you use vray as your default renderer?
                                kwistenbiebel
                                Just like any other render engine, Vray for Sketchup has it's little downsides.
                                It becomes a bit unstable when polycount increases and since it has no proxies/instancing feature, a very good Sketchup file size management is needed.
                                For instance, those trees needed some serious poly crunching before I could use one in the scene without crashing.
                                Vray is quite difficult to master. At first, the render settings panel and the material editor look quite scary. Once you get the hang of it it is not so hard and your workflow improves.
                                Most of the time it is about finding out which buttons to leave untouched, instead of which to use. 😄
                                Vray for sketchup was very buggy a time ago with a lot of workarounds that needed to be used,but things slowly seem to improve as Asgvis is pushing updates now on a more regular basis, which is a good evolution.
                                The render time on that latest image was appr. half an hour.
                                • StinkieS Offline
                                  Stinkie
                                  @princedragoncok said:
                                  How long did the v-ray render take? It is clearly better than the other renders(...)
                                  The other renders may not have "cooked" long enough. Vray's a great app, but Indigo's capable of better quality - if you got the time. 😉
                                  Nice image, Kwist. As always. Depressing, really. Certainly to someone like me, who's never been able to understand Vray. 💚
                                    kwistenbiebel
                                    Thanks 😉
                                    Indeed, unbiased render engines like Indigo, fry and Maxwell have the potential to create more physical correct output, but the render times can be longer to get crisp output.
                                    Not a problem for exteriors, but for interior scenes, a fairly powerful PC is needed.
                                      princedragoncok
                                      Interesting, the thing is I just can't be bothered getting stuck into indigo cause it takes so feicin long! Although, those guys that use blender on the indigo forum get amazingly crisp/clean images, I can only imagine they must have super computers. I can't see what's the advantage with unbiased renderers, the difference in quality isn't noticeable enough to justify the wait. 30 mins for that image is more than acceptable in my opinion. I guess it's the setup time i'm worried about..
                                      Shame it doesn't support instancing as well
                                      • StinkieS Offline
                                        Stinkie
                                        That of course depends on your needs. I need superb quality. I find the long render times horrific - but I have no choice. If you do, by all means, choose a biased renderer.
                                          princedragoncok
                                          Well I'm looking at this 30 min vray render here and it looks pretty superb to me, only crit is the floating leaves.
                                          However those blender guys on the indigo forum do make a convincing argument in favour of indigo..
                                          • StinkieS Offline
                                            Stinkie
                                            Don't get me wrong here, I'm not trying to convince you. I'm just pointing out there in fact is quite a noticeable difference in quality. The question is: do you need the quality that unbiased rendering provides? If so, you will indeed benefit from having a very good computer. If not, Vray might indeed be the thing for you - it is a very good renderer. I've seen many very compelling Vray renders. But: the learning curve is steep. That, or I'm stupid - which might very well be the case. 💚
                                            In short: both options have pros and cons. There's a third option, obviously. And that's waiting til Podium V2 is released.
                                            Repeat after me: Tavi, get off your *ss!! 💚
                                            • 4 / 6
