    2D 3D
    23 Posts 7 Posters 3.5k Views 7 Watching
      ridix
      Ok, I created simple 2D face me component.
      At first I was skeptical about drawing on front view. Because, when one draws in 3D space, SU always draws on red / green plane, and not on blue / red plane. Why does it work in this case?
      I am working on somewhat more complex 2D face me component. I am using line segments to create organic look; that way I can control line count. Biggest problem though is SU keep wanting to inference. The pen keep jumping / snapping at place where I don’t want the point to be! How do you stop it from snapping?
      • GaieusG
        Hi ridix,
        The plane you are drawing on is not incidentally chosen in SU. It always tries to "offer" the plane to draw on whose direction you are mainly looking at. So in Front/Back view you are draing on the red/blue plane, in Left/Right view you are drawing on the green/bue plane while in Top/Bottom view on thered/green plane.
        When not in these standard views and simply navigating in 3D, most users tend to draw things looking at them from a bit of above therefore the majority of the screen is occupied by the red/green plane. But if you orbit up a bit so that the sky is more visible (looking horizontally), you can change this.
        Many new users are annoyed by how hard it seems to draw on another plane than the red/green one but once you know the "trick" and get used to it, it_'s not hard any more.
        As for the inference engine while in Free hand mode - well, yes, that's a pain and the only way to avoid it is to zoom in when you can't get it right. But remember; SU is not a drawing program. Most people use some 3rd party software to do this kind of things and then import the files into SU.
        Another simpler way to create nice 2D components is to use semitransparent images on the face, hide the edges and there you go - no need to trace around with the Freehand tool. The only drawback (still in SU6) is that the shadows will remain rectangular but with just a couple of rough outlines you can get them fixed.
        • Wo3DanW
          Wo3Dan
          @ridix said:
          ...... Biggest problem though is SU keep wanting to inference. The pen keep jumping / snapping at place where I don’t want the point to be! How do you stop it from snapping?
          ridix,
          It's likely that you have 'Enable length snapping' checked.
          To ease things when drawing (reduce jumpy cursor behaviour) just uncheck this feature:
          Window > Model Info > Units > disable (uncheck) lenght snapping. (or reduce value as much as possible)
          Wo3Dan
            ridix
            Thanks for you input all. Here is my second more complex 2D face me component; a roman soldier.
            http://www.designonme.com/sketchu/roman1.jpg
            • GaieusG
              Now that's cool (in fact I am an archaeologist specified in Roman provincial archaeology and have dug in several Roman forts so far 😄 )
              Now edit the components and hide the dges. From a distance those profile lines will simply cover the whole face.
                ridix
                Ya, as the image shrinks they tend to go black. Bigger problem is 2D face me object are semitransparent. As in this image, shadow show through adding quite a bit of clutter. Is there a way to make it completely opaque?
                http://www.designonme.com/sketchu/roman2.gif
                Ok, so that is where your Avatar comes from. I am no archaeologist but one of my hobbies is flint knapping. I can now make halfway decent projectile point out of obsidian. One might think making Stone Age tool is simple, but it is no easy task to make a nice lethal point. You need right tool, right material, and right technique to make it.
                  remus
                  First thing to do to get the soldiers non-transparent would be to check the image you cut it out from in the materials browser. If you click the 'edit' tab you should get a little opacity slider at the bottom, make sure its at 100%.
                  If it's the iamge itself thats transparent, you'll need to pen up your image editro of choice and make it non transparent, you should then be able to import it back in to SU and use it as a projected texture to go over your old texture.
                    ridix
                    Ups, sorry, I had X ray turned on!
                    • GaieusG
                      That was my other guess 😄
                      Would you mind sharing the image?
                        ridix
                        Here is the image. With only this many roman solders, my pc is starting to slow down! No go to make a Roman legion.
                        http://www.designonme.com/sketchu/roman3.gif
                        • GaieusG
                          Hide the outside edges - it will ease your performance problems (and the soldiers would look better, too).
                          • Alan FraserA
                            Alan Fraser
                            I'm assuming that the Roman Legionary is all geometry...as with the standard SU Face Me people. This can lead to an awful lot of edges when you start multiplying up the number of figures.
                            One way of avoiding this is to take a render of your figure, then use that image to create a "photo" version. This will allow you to get rid of all the interior lines. You can further reduce the number of edges by making the background of your exported image transparent and saving it as a png file. If you leave the imported png figure as-is, it will cast a rectangular shadow, so it's best to cut it out. However, you can be fairly brutal about this, because the transparency in the image takes care of the silhouette of the figure itself. You are only cutting it out for the sake of a realistic shadow...which is likely to be distorted anyway; so you can afford to make a very simplistic outline.
                            I've used this process here...not quite a Legion but 4 maniples, making up a cohort of 480 men...and it's still navigable (even more so with shadows turned off).
                            cohort.skp
                            3D Figures
                              ridix
                              Looking good!
                              SU seems to use lots of CPU crunching when it comes to displaying edges. I have been using C4D for some time. With that software if you are not careful, one can easily create over a million polygons; that’s 3 to 4 million edges! And it still display ok on my PC. What is going on with SU anyway?
                              • Alan FraserA
                                Alan Fraser
                                The general belief is that the same inferencing that makes it so easy to draw in 3D in a single window is constantly keeping track of a good many vertices in the model, thus making the program rather geometry-intolerant. That's why it's often a good idea to offload some of the work onto the graphics processor, by using images, rather than pushing everything through the CPU.
                                3D Figures
                                  Yes, SU doesn't deal with too many polygons too well. Outlines and shadows multiples the strain many times. I tend to only use them when I export images or for very light models.
                                    480 armed men always facing your direction... scary... 😆
                                    I found that using using billboard images instead of drawn outline work much faster as well. I tried making a forest with the default SU tree and that bogged down very quickly. And I got a decent card, nVidia Quadro 3500. But using billboards made a huge difference. Something which was a great bonus to me when I render in V-Ray.
                                    • W
                                      wyatt
                                      Back to something that Remus & Gaieus said early in this thread...
                                      When creating a new face-me component, I don't have the face-camera option available in the original file that is saved in the Components folder (call this the Base file). I only see that option if I add the component to a new model, explode it, and create a new component in my new model. This is time-consuming to edit each component after I've inserted it into the model. I've looked at components I've downloaded from users on this forum and those that come with SU. These base files are strictly geometry (not components). Some can be inserted correctly as face-me components, others not. There is nothing unique (that I can see) about the files that work as face-me's versus the one's that don't. There's got to be an easy fix for this, but I sure can't remember/find what it is.
                                      Thanks for the help.
                                      Wyatt
                                      • Alan FraserA
                                        Alan Fraser
                                        I'm not sure I follow exactly what you are saying, but my experience is that the 2D Face Me components that come with SU (and similar ones I make for FormFonts) are just that...components. Whereas the Face Me components that people generally post to this forum are embedded components. In other words, the file itself is a component, but it has a duplicate of itself in the component browser.
                                        This is achieved by making a Face Me in the usual way (at which time it appears in the browser, like any other component) then saving the entire file. If you think about it, this is not the way you would save an ordinary component. You wouldn't, for instance, model a chair, then make it a component, then save the file...you'd just save the file. Obviously, if you do this with a Face Me, you have no way of actually specifying that it is a Face Me. The answer is that you do make it a Face Me component, but you don't save the whole file (with the embedded component) you right-click the component in the browser and save that instead...then discard the original file. This will save the component as a Face Me, but it will just be the straight geometry...there won't be a copy of itself in the browser, nor will it actually rotate when opened. Face Me components only rotate when imported into another file.
                                        The only slight bug in this process at the moment is that when Face Me files are saved in this way, then opened, you can't see anything, because the camera zoom appears to default to a position about 1mm away from the origin. So you need to zoom to extents then resave.
                                        3D Figures
                                        • W
                                          wyatt
                                          Thanks Alan. I was trying to edit the component in its base file. When I insert the component into a new file, explode it, and resave it from the component browser I'm able to turn on the face-me features. It seems like there are some added steps there that slow down the workflow, but I'll live with it. Thanks again for the explanation.
                                          Wyatt
