    Benefits of Pro over Free?
    19 Posts 12 Posters 2.8k Views 12 Watching
      @thomthom said:
      And High Quality print.
      No Tom, that is now included into the free version as well (regardless of what the SU Guide indicates). In SU 5 these things were the difference (missing from the free version):
      • Sandbox tools
      • Print options (only limited to screen resolution)
      • animation export
      • Model location (in Windows)
      • 3D and 2D vector exports
        Now only the two latter are the difference - with kmz being a 3d export option for the free version as well - and Jim has a script for model location in the free version.
        twharvey
        @sorgesu said:
        In addition, you are unable to change the model location from the default Boulder, Colorado and this will impact your shadow studies. However, this can be overcome there is a free ruby script available that will allow you to do so.
        What is the ruby script called? Or is there a link to it?
        Thanks,
        Tom
        Tom
        • W Offline
          watkins
          Dear Tom,
          Good morning! I see that you are another early riser.
          You can find Jim's most excellent script here:
          Plugin: Model Location
          * This plug-in was made for SketchUp version 6 Free because it lacked the dialog (which Pro had) to change these settings. This has become ...
          (sketchuptips.blogspot.com)
          Take time to browse his other offerings. He is both industrious and generous.
          Kind regards,
          Bob
            twharvey
            Thanks, Bob. Yeah, seems the older I get, the less I sleep.
            Tom
            Tom
              Hi Tom, Hi Bob,
              @Tom - I know you often model for GE. Note that whenever you take a snapshot from GE, it will also get the location precisely. The script for the Free version (or the Location tab for the Pro verswion) is only important when you don't take the snapshot - i.e. not modeling for GE.
                twharvey
                Thanks, Gaieus.
                Tom
                • John SayersJ Offline
                  John Sayers
                  the advantage of Pro over free is you can use it professionally and charge for your work.
                    John,
                    Since SU 6 came out, there is no "non-commercial" limitation on SU Free either.
                      John Sayers
                      thanks for that info - it would have been very hard to police anyway. πŸ˜‰
                        Julius
                        sill nobody answered to the question: "Do the people who bought the Pro version think it is worth $500?"
                          remus
                          I'd say, yes it is worth it if your a professional and you need to be able to export models easily, otherwise it's not worth the money.
                          • jujuJ Offline
                            juju
                            I suppose it depends on what you use it for. It is really only something you can answer for yourself, all the necessary guidance to make that decision have been given in previous posts.
                            • soloS Offline
                              The answer is simple really, most folk that bought the professional version were indeed using it in a professional capacity and in doing so their workflow would probably require exporting and importing over several other apps in order to deliver the final product. I cannot comment about the Layout feature as I have never had the patience to deal with it and it never yielded anything productive in my hands.
