    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
    • T
      thinkbuild
      well well i fixed it! strange. i wiped out all of my plugins, started again, one at a time, and now it is fine.
      so, the only thing i learned is that you CAN mess up your sketchup by having too many plugins. but i should have realized that... i am going to erase the posts above. sorry to all if i wasted anyone's time ... ;(
        A friend of mine just downloaded Joint Push/Pull from Didier's site. Now when he opens SketchUp he gets the following:
        Error Loading File jointpushpull.rb
        C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2356: syntax error
        menu.add_item(Traductor[DLG_MnuRedo) { JointPushPull.redo }
        C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2378: syntax error
        Any ideas of what needs to change?
        • fredo6F
          Dave,
          Strange because this bugs existed only for one hour in the life of this script (see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6713&start=15#p43230).
          But the version on Crai Ruby Depot does contain the bug apparently. Thanks for signaling.
          A working version is anyway available on the present forum at http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=6708#p42783
          Didier: When you can, can you please update on your site (and also indicate that it works on Sketchup 5).
            Thanks Fredo.
            He has the updated version and all is well.
            Cheers,
            Dave
            • P
              pibuz
              AMAZING! REALLY AMAZING! NO OTHER WORDS!
              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
              • ely862meE
                ely862me
                u did it!! yes!!....bravoooooo!!!
                i would never can thank u enough πŸ˜‰
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=8821
                Elisei (sketchupper)
                Come and See EliseiDesign
                  sho inostar
                  @dave r said:
                  Thanks Fredo.
                  Cheers,
                  Dave
                    Rodentpete
                    Excellent! Between this and OOS I am going to save so much time modelling, thanks for all the hard work you've put in.
                    • N
                      neoshed
                      Many thanks for your effort on these scripts, to quote Push Pull Bar "CRACQUER"
                        marcociacci
                        This Plugin is FANTASTIC!!! thank you
                          digby dart
                          Thank you for your generosity in sharing this excellent script Fredo6. It works beautifully. I now consider your icons an essential part of the Sketchup screen.
                          • T
                            topmanblue
                            Oh~~~~~~~~~~~~~~~~my God!!!!!!!!!!!!!!!!!!!!!!!!!!!thank u
                            • W
                              wq418
                              it's cool!!!
                              thank you
                              • P
                                pix_zaaaaa
                                Good πŸ˜„ πŸ˜„ πŸ˜„
                                  mpowell1234567890
                                  I'm trying to use joint push pull on a model but everytime I use it - Sketchup freezes. is there a way to fix it?
                                  • GaieusG
                                    Michael,
                                    The progress (push/pull operation) is displayed in the status bar. Does it seem to work (and maybe the progress is just too slow) or is that frozen as well?
                                      mpowell1234567890
                                      @gaieus said:
                                      Michael,
                                      Both. It happens with a large model. "For example, I made a large maze type shape using a "cubic benzier" or "the freehand" tool. then I clicked on the shape to select it. Then I used the joint push pull to push pull it. 1st click I chosen the height, but when I click it the 2nd time - after a minute, it freezes up.
                                      • fredo6F
                                        So, Can you confirm this works fine with small model?
                                        Then, how large is the 'large model'?
                                        Although there are surely limits to how many faces and segments you can handle (due to limits in Ruby memory allocation), JPP usually takes very long when there are many elements. Because Ruby is not multi-threaded within Sketchup, it may 'freeze' Sketchup and even the progress bar, while computing. This may take minutes or longer, but may well end up at some point in time. If you can, try this before doing something else than computing to see if it finally finishes.
                                        • plot-parisP
                                          plot-paris
                                          if I do large jpp operations, SketchUp sometimes freezes (certainly, if I click somewhere else).
                                          therefore I wait the first 30 seconds, look in the status bar how many faces are done and how many are still left. thus I can calculate a rough remaining time (which normally precisely matches the real time needed).
                                          then I go to the SCF forum and enjoy live until suddenly (sometimes after 10 minutes or so) SketchUp draws my attention to it by becoming active again...
                                          so Joint Push Pull and SCF-forum work hand in hand πŸ˜„
                                          • boofredlayB
                                            boofredlay
                                            Great idea Jakob!
                                            Fredo, maybe you should ad a progress bar that has a link to the SCF...
                                            "While you wait for your mesh to be created, please enjoy the SCF". πŸ˜„
                                            You could even add some elevator music to go along with it.
                                            Ok, I am done amusing myself today.
                                            • 18
                                            • 19
                                            • 4 / 19
