    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
      a4chitect
      sound reasonable - thanks for explaining! is this part of your script already? or should I dive into it?
        thinkbuild
        dear fredo6
        greetings from berlin. fredo6 - i'd say, don't spend too much time on this. your development is very important to many of us i think, so keep going. i think this is the priority. in the meantime, i think i might try your script with a fresh install on another machine to see if i have made this happen through a script conflict...? also, i can always re-install the first version for my "real" work...
        BUT, just in case you are still curious and because you asked the question, i tested the script with the other two tools to answer your question. what i discovered is that it crashes in (i think) exactly the same way. attached are the two logs.
        my method was as follows:
        1. open a new drawing in a new SU session.
        2. draw a box.
        3. push pull it up a bit (with the regular tool).
        4. pick a face.
        5. use one of the three tools.
        6. it starts - says, "double click or press enter to begin...)
        7. (pause) ... progress bar moves ... then ...
        8. <blank>
        9. SU disappears, i am in the finder ...
        my biggest question is: why does the original script work and the new one not? what has changed? and, are any other mac users having this or similar problems? i am very curious. any mac people out there to comment...?
        the mystery continues....
        i've also attached the traductor pieces to make sure they aren't causing the problem....
        best wishes to all
        jason
        thinkbuild-mac-joint-pull-crash-log-normal-push-pull.txt
        thinkbuild-mac-joint-pull-crash-log-vector-push-pull.txt
        LibTraductor.rb
          thinkbuild
          well well i fixed it! strange. i wiped out all of my plugins, started again, one at a time, and now it is fine.
          so, the only thing i learned is that you CAN mess up your sketchup by having too many plugins. but i should have realized that... i am going to erase the posts above. sorry to all if i wasted anyone's time ... ;(
            A friend of mine just downloaded Joint Push/Pull from Didier's site. Now when he opens SketchUp he gets the following:
            Error Loading File jointpushpull.rb
            C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2356: syntax error
            menu.add_item(Traductor[DLG_MnuRedo) { JointPushPull.redo }
            C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2378: syntax error
            Any ideas of what needs to change?
            • fredo6F Offline
              Dave,
              Strange because this bugs existed only for one hour in the life of this script (see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6713&start=15#p43230).
              But the version on Crai Ruby Depot does contain the bug apparently. Thanks for signaling.
              A working version is anyway available on the present forum at http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=6708#p42783
              Didier: When you can, can you please update on your site (and also indicate that it works on Sketchup 5).
                Thanks Fredo.
                He has the updated version and all is well.
                Cheers,
                Dave
                  pibuz
                  AMAZING! REALLY AMAZING! NO OTHER WORDS!
                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                  • ely862meE Offline
                    ely862me
                    u did it!! yes!!....bravoooooo!!!
                    i would never can thank u enough πŸ˜‰
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=8821
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                      sho inostar
                      @dave r said:
                      Thanks Fredo.
                      Cheers,
                      Dave
                        Rodentpete
                        Excellent! Between this and OOS I am going to save so much time modelling, thanks for all the hard work you've put in.
                        • N Offline
                          neoshed
                          Many thanks for your effort on these scripts, to quote Push Pull Bar "CRACQUER"
                            marcociacci
                            This Plugin is FANTASTIC!!! thank you
                              digby dart
                              Thank you for your generosity in sharing this excellent script Fredo6. It works beautifully. I now consider your icons an essential part of the Sketchup screen.
                                topmanblue
                                Oh~~~~~~~~~~~~~~~~my God!!!!!!!!!!!!!!!!!!!!!!!!!!!thank u
                                • W Offline
                                  wq418
                                  it's cool!!!
                                  thank you
                                    pix_zaaaaa
                                    Good πŸ˜„ πŸ˜„ πŸ˜„
                                      mpowell1234567890
                                      I'm trying to use joint push pull on a model but everytime I use it - Sketchup freezes. is there a way to fix it?
                                        Michael,
                                        The progress (push/pull operation) is displayed in the status bar. Does it seem to work (and maybe the progress is just too slow) or is that frozen as well?
                                          mpowell1234567890
                                          @gaieus said:
                                          Michael,
                                          Both. It happens with a large model. "For example, I made a large maze type shape using a "cubic benzier" or "the freehand" tool. then I clicked on the shape to select it. Then I used the joint push pull to push pull it. 1st click I chosen the height, but when I click it the 2nd time - after a minute, it freezes up.
                                          • fredo6F Offline
                                            So, Can you confirm this works fine with small model?
                                            Then, how large is the 'large model'?
                                            Although there are surely limits to how many faces and segments you can handle (due to limits in Ruby memory allocation), JPP usually takes very long when there are many elements. Because Ruby is not multi-threaded within Sketchup, it may 'freeze' Sketchup and even the progress bar, while computing. This may take minutes or longer, but may well end up at some point in time. If you can, try this before doing something else than computing to see if it finally finishes.
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
