    Organic modelling question
    21 Posts 8 Posters 3.8k Views 8 Watching
      princedragoncok
      Many thanks for the replies. To be honest this will never be built and is just something for both of our portfolios. I haven't a clue how to write scripts either but it might be worth investing some time in remus' idea which sounds best to me
      Maybe you could modify the tree generator script to give you lots of follow me paths in a sort of organic shape, you could then get a rectangle to follow along each path, intersect the whole thing, clean it up as best as you can and then subd and smooth.
      And another question regarding the tapering -
      Then you could Zorro the top parts and the scale the end of the tube to create the tapers.
      How is it possible to scale just the top parts? I'm trying to imagine it with a rectangle now.. wouldn't the whole thing just be equally scaled/stretched? Is there some way to just select a portion of a rectangle?
      • F Offline
        fbartels
        Clearly someone is making shapes like this... or this is a very good render 😄
        http://ffffound.com/image/fb8c3ee691900b17e6f73065e127243713eb382b
        • soloS Offline
          A difficult endeavor no doubt.
          How about creating a curved face then using curved face tools (Fred's script) to cut out shapes. Then using JPP (fred script again) to pull depth. Once you have a few variations of these then you can use Whaat's Sub-smooth script to soften the edges in order to look organic?
            princedragoncok
            Cool thanks, I'll look into getting those scripts.
              remus
              Fred, those look significantly simpler, i reckon you could do those just by usign a load of push pulled rectangles and subd and smooth. I might do a quick test when i get home...wish me luck 😛
                johnsenior1973
                You just select the top face. And you use the Zorro (or knife if you have Subdivide and Smooth) close to the top so that is the only part that is affected.
                A rectangle wouldn't be the best example because it would just create two triangles on each verticle face and would look pretty bad. The best way to demonstrate this would be to use the free hand draw to create a random shape.
                  princedragoncok
                    remus
                    Well heres a very quick first go at it:
                    http://farm4.static.flickr.com/3207/2490395740_61f7a3b630_o.jpg
                    I reckon it might work with some further refinement. We'll see.
                      princedragoncok
                      Nice one Remus, you're certainly on the right track. how did you do it?
                        remus
                        Here you go, did a quick tut.
                        Main points to note: this method gets very boring very quickly, although i imagine once youve done maybe 5 strand proxies you could just copy and rotate them. This would speed things up quite a bit.
                        The finished model is also likely to have a lot of polys, so try and keep the number of subd and smooth iterations as low as possible.
                        tendon tut.skp
                          princedragoncok
                          Thanks very much for taking the time to do this Remus 😛 . Don't have sketchup on this comp but will check it out when I get home
                            princedragoncok
                            great tutorial remus, thanks alot. Can't beleive how easy it is with subdivide and smooth. an amazing tool. Nice one too fred
                              remus
                              Indeed it is a very cool plugin, it opens up a whole world of possibilities.
                              One word of warning though, its very easy to get carried away and rnd up with millions of polys on a spoon, this tends to slow SU down a lot, especially if you decide you want to model a matching teapot to go with your spoon.
                                matteo
                                You may give a try to Topmod:
                                http://www-viz.tamu.edu/faculty/ergun/research/topology/
                                It is free and can reads & save obj files.
                                /matteo
                                hire me: http://www.nonsolo3d.it/ !
                                  Jorgensen
                                  Wow, now that's crazy ! 😲
                                  • F Offline
                                    fbartels
                                    A variation on Remus's approach. It's not your Daddy's SketchUp ... subd and smooth ... oh my gosh ... the possibilities!
                                    http://dws.editme.com/files/MayJune2008/nyds small.jpg
