    Lighting Plugin for Sketchup
    232 Posts 67 Posters 85.2k Views 67 Watching
    • jujuJ Offline
      juju
      I get this error message when I press the LightUp prefences button.
      If you press "yes" you can continue onto the settings window, but supersampling cannot be enabled.
      • AdamBA Offline
        AdamB
        @edson said:
        @adamb said:
        @mike lucey said:
        I will be posting some video tutorials. Any suggestions as to areas that would benefit most, would be much appreciated.
        AdamB
        adam,
        no problems whatsoever downloading and installing LightUp in my mac.
        i have started playing with it but, being a novice at rendering in general, it would be great to have a couple of tutorials or videos demonstrating a typical workflow. this will certainly allow us to make the best of LightUp.
        a question: the time limit of 30 minutes means that everytime i open SU i have 30 min to use LU? what if a render takes more than that? if i am misunderstanding this please enlighten me.
        it is difficult to navigate within the studio skippy you posted as there are no scenes set up. if one makes any false move the only way to get back to the scene is close and reopen the file.
        congratulations on your effort.
        Generally LightUp rendering is pretty quick (obviously it depends on the model complexity) so 30 minutes seemed reasonable to give people a go with the technology to see if its useful to them. I've certainly added onto the TODO list something to allow you to quit from rendering if its taking too long - or there's a bug causing LightUp to spin endlessly.
        As to getting lost in studio2.skp Yes, it was modelled with no scale in mind hence the crazy dimensions. However, you can control the speed of the camera motion in LightUp from the Preferences dialog. In "Viewing" look for "Speed". Also, if you ever get lost anywhere in Sketchup, Apple/Ctrl-1 to reset the camera position is always helpful.
        Adam
        • AdamBA Offline
          AdamB
          Juju: supersampling is not available in this version
          Correct! And I have a question mark as to its usefulness too. Currently its a rotating multi-tap kernel but I'm thinking you might as well just turn up the Resolution of the lighting to achieve much the same effect.
          Adam
          • AdamBA Offline
            AdamB
            feedback:
            • model that is in the manual should be added to get on track easily
            Yes, for the actual release there will be examples, videos etc.
            • output bug: see attached (happened several times, cannot duplicate)
            • better icons 💚 (too much antialias when Larg Icons is set)
            I have had some OpenGL drivers create odd snapshots. Try adjusting the size of the window (which will in turn change the size of the output size.)
            • a way to disable the debug text from Ruby console
            Yep, I plan to. Left it in for now since it doesn't do much harm. But yes I agree.
            • in direct lighting do not apply sun if it is not selected
            Can you explain. "Use sun" is selected by default. If you turn it off, LightUp shouldn't use the Sun.
            ideas:
            • overlay on top of SU output with custom opacity - to have the lines visible
            Hmm. I have the greatest respect for the SU developers, but there OpenGL backend is the slowest thing I have ever seen. I don't know what goes on behind the scenes, but anything I can do to get as far away from it is going to help performance. If there is real call for lines - I'll draw 'em!
            nice work Adam 👍
            Thank you. Fair amount of work to do yet!
            Adam
            • AdamBA Offline
              AdamB
              [attachment=0:2jd7eubv]<!-- ia0 -->lightup preferences error dialog.JPG<!-- ia0 -->[/attachment:2jd7eubv]
              Its something to do with Explorer that I've yet to entirely track down.
              If you get this a lot, you can reset the Preferences for a model from Ruby Console. Type:
              LMap.resetprefs
              • tbdT Offline
                tbd
                aha, I thought that it takes in account "display shadows" from SU. didn't saw the "Use sun" from preferences window.
                why not use the "display shadows" ? more intuitive imho
                http://plugins.ro
                • AdamBA Offline
                  AdamB
                  Well possibly. Its an interesting one because I think the dynamic for Podium is slightly different. I've found myself often not having shadows in SU but wanting sunlight shading in LU as a flick between the two. For Podium you want to compose the view "just so" and press the big green button and demand you get the same settings as in SU.
                  In any case, its a 1 line change to check LUprefs or the SU rendering_options.
                  Adam
                  • BurkhardB Offline
                    Burkhard
                    Hi Adam, I made a mistake with the licence key 0 and O. Where can I get the second chance? I can't find the new registration field.
                    Edit Solved.
                    http://www.ia-plus.de
                    • AdamBA Offline
                      AdamB
                      Edit Solved.
                      Just for future reference. In menu Tools->LightUp->Reset Registration Key then Quit Sketchup.
                      Adam
                      • AdamBA Offline
                        AdamB
                        A couple of video tutorials to get people started using LightUp.
                        The first shows how to set up a Point Light source and is available
                        http://uk.youtube.com/watch?v=Qtyj40CS6tg
                        The second shows how to set up Area Light sources and is here http://uk.youtube.com/watch?v=EhpRDCqbGA4
                        • tbdT Offline
                          tbd
                          Adam: thanks for the video tuts.
                          you can even do psychedelic renders 💚
                          later edit: get some crashes (when freeing memory after writing .luca files)
                          psychedelic render
                          here is the file
                          http://plugins.ro
                          • EdsonE Offline
                            Edson
                            thanks, adam. very informative indeed. it cleared up some doubts i had after reading the users guide, being the rendering dummy that i am.
                            please keep the videos coming!
                            http://www.mahfuz.arq.br
                              kwistenbiebel
                              Yes, the videos clarify a lot.
                              Thank you.
                              • jujuJ Offline
                                juju
                                Thanks for the tuts Adam, as a matter of note, the RSS feed I have bookmarked for your site fails to load, has been for a couple of days.
                                Adam, any chance your LightUp application/plugin will be compatible with Podium (application/plugin by TBD)?
                                I think it will be quite useful if I can set up the scenes in SU, check them out and have pre-vis and later, once modeling is all done, render it in Podium without having to redo the lighting.
                                • JClementsJ Offline
                                  JClements
                                  Neophyte question.
                                  I seems that Area lights and Spot lights are similar. What is the difference between the two?
                                  • EdsonE Offline
                                    Edson
                                    neophyte reply: i think when you use an area light you see the source of the light but when using a spotlight you do not. of course, i may be wrong.
                                    • AdamBA Offline
                                      AdamB
                                      Hmm.. 😮 You get that when the LightUp has stale data wrt SketchUp. It shouldn't happen of course and I'm working on a fix. One way of forcing a resync of LightUp is to add a single line to the model somewhere. It won't show in LightUp but does trigger a rebuild because the model is considered "changed". I know, its ugly!
                                      [Useless info #1. They're called luca files because I was writing the code with Luca (my son on my knee) and he wanted something named after him - and "LightUp Cache files" kinda fitted!]
                                      • AdamBA Offline
                                        AdamB
                                        I'll look into it.
                                        Well I did add some Podium support after speaking with TBD. It used to pick up Light Power from the face attributes (BTW it picks up some Kerky attributes too). But then just before I posted the demo I saw that Podium 2.0 is dropping per face attributes so I pulled it to stop a mass of confusion.
                                        Adam
                                        • AdamBA Offline
                                          AdamB
                                          @jclements said:
                                          Neophyte question.
                                          LightUp doesn't have spotlights per se. It has Point Lights that radiant evenly in every direction, and Area Lights which radiant in a "spread angle" around the face direction (eg 90 degrees means radiant in a hemisphere). So you can create "spot faces" (aka spotlights) simply by giving an area light a small spread angle and big power. I tend to wrap light sources into components just for ease of use.
                                          Adam
                                            Max_B
                                            After I made a "clean unused components" in one file, I no longer see point light component in the material palette (nor the cache). Even after SU restart and LU reinstall.
                                            They both are there, i can click on white place holders and add them. Just they don't show up.
                                            How can I get the icons back?
                                            • 11
                                            • 12
                                            • 8 / 12
