    Lighting Plugin for Sketchup
    232 Posts 67 Posters 85.2k Views 67 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Thanks Adam, everything opened fine. I've printed the instructions
      and will read and have go tomorrow.
      I really like the icons and way you have presented the package. Do
      you use a Mac by any chance?
      Mike
      PS: Maybe you have done this already, I haven't checked on the forum.
      Is there a Video Tutorial available showing a step by step approach?
      • AdamBA Offline
        AdamB
        @ilay7k said:
        Adam what about if somebody made scene and configured lightUp's options, and remotely sent to other...how to start rendering?
        for example your studio-file, i open and what i do to start simulation? when i push TourTool and there is no actions...then add AO and push TT, it works fine
        The lighting options etc are all stored with the .skp file so sending it to somebody else will retain that info. The lighting data is created locally and NOT currently saved with the skp file.
        The TourTool checks to see whether you've created lighting data and only starts if you have. So creating either Ambient Occlusion or Direct lighting (or both!) will then allow TourToool to start.
        Adam
        • AdamBA Offline
          AdamB
          Mike
          Thank you. Yes, I regularly use Macs and PCs though my main machine is a G5 Mac.
          I will be posting some video tutorials. Any suggestions as to areas that would benefit most, would be much appreciated.
          AdamB
          • I Offline
            ilay7k
            Thank you for explanation
            and when i modify geometry and some features in my scene, can i reset previous setting: remove LU-layer or something?
            Thanks,
            i move to LU's forum...is it open?
            • AdamBA Offline
              AdamB
              @ronanr said:
              @adamb said:
              @jclements said:
              I downloaded the zip file, went to its properties and unblocked it, but still couldn't extract the contents without the Windows Block Content dialog.
              Sounds like you have a virus-checker stopping the installation. Perhaps you should install elsewhere and move the files manually.
              No, its Windows 'deciding' the content can be harmful... my Norton AV passes your zip file as clean... Perhaps the ability to download the installer Unzipped from Light-up.co.uk would help some people with the same problem? Just a thought.
              Its the .msi file that is causing problems for JClements I believe so I'm not sure that would help.
              I think there is bound to be a "learning experience" for me about the best way of packaging and downloading this stuff for minimal aggravation over the coming weeks!
              • EdsonE Offline
                Edson
                @adamb said:
                AdamB
                adam,
                no problems whatsoever downloading and installing LightUp in my mac.
                i have started playing with it but, being a novice at rendering in general, it would be great to have a couple of tutorials or videos demonstrating a typical workflow. this will certainly allow us to make the best of LightUp.
                a question: the time limit of 30 minutes means that everytime i open SU i have 30 min to use LU? what if a render takes more than that? if i am misunderstanding this please enlighten me.
                it is difficult to navigate within the studio skippy you posted as there are no scenes set up. if one makes any false move the only way to get back to the scene is close and reopen the file.
                congratulations on your effort.
                edson mahfuz, architect| porto alegre โ€ข brasil
                http://www.mahfuz.arq.br
                • tbdT Offline
                  tbd
                  feedback:
                  • model that is in the manual should be added to get on track easily
                  • output bug: see attached (happened several times, cannot duplicate)
                  • better icons ๐Ÿ’š (too much antialias when Larg Icons is set)
                  • a way to disable the debug text from Ruby console
                  • in direct lighting do not apply sun if it is not selected
                  ideas:
                  • overlay on top of SU output with custom opacity - to have the lines visible
                  nice work Adam ๐Ÿ‘
                  lightup save image output
                  http://plugins.ro
                  • tbdT Offline
                    tbd
                    Juju: supersampling is not available in this version
                    http://plugins.ro
                    • jujuJ Offline
                      juju
                      Makes sense then, thx TBD.
                      Also, the room scale (studio2.skp file) seems to off quite a bit. I use the position camera and point to a place on the floor, eye height set to 5'6" and I'm virtually as tall as the room.
                      • jujuJ Offline
                        juju
                        I get this error message when I press the LightUp prefences button.
                        If you press "yes" you can continue onto the settings window, but supersampling cannot be enabled.
                        • AdamBA Offline
                          AdamB
                          @edson said:
                          @adamb said:
                          AdamB
                          adam,
                          Generally LightUp rendering is pretty quick (obviously it depends on the model complexity) so 30 minutes seemed reasonable to give people a go with the technology to see if its useful to them. I've certainly added onto the TODO list something to allow you to quit from rendering if its taking too long - or there's a bug causing LightUp to spin endlessly.
                          As to getting lost in studio2.skp Yes, it was modelled with no scale in mind hence the crazy dimensions. However, you can control the speed of the camera motion in LightUp from the Preferences dialog. In "Viewing" look for "Speed". Also, if you ever get lost anywhere in Sketchup, Apple/Ctrl-1 to reset the camera position is always helpful.
                          Adam
                          • AdamBA Offline
                            AdamB
                            Correct! And I have a question mark as to its usefulness too. Currently its a rotating multi-tap kernel but I'm thinking you might as well just turn up the Resolution of the lighting to achieve much the same effect.
                            Adam
                            • AdamBA Offline
                              AdamB
                              feedback:
                              Yes, for the actual release there will be examples, videos etc.
                              I have had some OpenGL drivers create odd snapshots. Try adjusting the size of the window (which will in turn change the size of the output size.)
                              Yep, I plan to. Left it in for now since it doesn't do much harm. But yes I agree.
                              Can you explain. "Use sun" is selected by default. If you turn it off, LightUp shouldn't use the Sun.
                              ideas:
                              Hmm. I have the greatest respect for the SU developers, but there OpenGL backend is the slowest thing I have ever seen. I don't know what goes on behind the scenes, but anything I can do to get as far away from it is going to help performance. If there is real call for lines - I'll draw 'em!
                              nice work Adam ๐Ÿ‘
                              Thank you. Fair amount of work to do yet!
                              Adam
                              • AdamBA Offline
                                AdamB
                                [attachment=0:2jd7eubv]<!-- ia0 -->lightup preferences error dialog.JPG<!-- ia0 -->[/attachment:2jd7eubv]
                                Its something to do with Explorer that I've yet to entirely track down.
                                If you get this a lot, you can reset the Preferences for a model from Ruby Console. Type:
                                LMap.resetprefs
                                • tbdT Offline
                                  tbd
                                  aha, I thought that it takes in account "display shadows" from SU. didn't saw the "Use sun" from preferences window.
                                  why not use the "display shadows" ? more intuitive imho
                                  http://plugins.ro
                                  • AdamBA Offline
                                    AdamB
                                    Well possibly. Its an interesting one because I think the dynamic for Podium is slightly different. I've found myself often not having shadows in SU but wanting sunlight shading in LU as a flick between the two. For Podium you want to compose the view "just so" and press the big green button and demand you get the same settings as in SU.
                                    In any case, its a 1 line change to check LUprefs or the SU rendering_options.
                                    Adam
                                    • BurkhardB Offline
                                      Burkhard
                                      Hi Adam, I made a mistake with the licence key 0 and O. Where can I get the second chance? I can't find the new registration field.
                                      Edit Solved.
                                      http://www.ia-plus.de
                                      • AdamBA Offline
                                        AdamB
                                        Edit Solved.
                                        Just for future reference. In menu Tools->LightUp->Reset Registration Key then Quit Sketchup.
                                        Adam
                                        • AdamBA Offline
                                          AdamB
                                          A couple of video tutorials to get people started using LightUp.
                                          The first shows how to set up a Point Light source and is available
                                          http://uk.youtube.com/watch?v=Qtyj40CS6tg
                                          The second shows how to set up Area Light sources and is here http://uk.youtube.com/watch?v=EhpRDCqbGA4
                                          • tbdT Offline
                                            tbd
                                            Adam: thanks for the video tuts.
                                            you can even do psychedelic renders ๐Ÿ’š
                                            later edit: get some crashes (when freeing memory after writing .luca files)
                                            psychedelic render
                                            here is the file
                                            http://plugins.ro
                                            • 11
                                            • 12
                                            • 8 / 12
