    Lighting Plugin for Sketchup
    232 Posts 67 Posters 85.2k Views 67 Watching
    • I Offline
      ilay7k
      Daniel, try this
      1. create any mesh(with any mat)
      2. Add sketchup shadow
      3. Select all(geometry) and push Ambient Occlusion, then Direct Illumination
      4. TourTool
      John extract by free 7-zip ...or winzip, WinRar
      i unpacked normally...
      • AdamBA Offline
        AdamB
        @daniel s said:
        :? ๐Ÿ˜•
        I must be doing something wrong..
        can you post a .skp example like the ones you use to make the images on your web Adam? ๐Ÿ˜’
        Daniel S
        There you go.
        studio2.skp
        • AdamBA Offline
          AdamB
          @jclements said:
          I downloaded the zip file, went to its properties and unblocked it, but still couldn't extract the contents without the Windows Block Content dialog.
          Sounds like you have a virus-checker stopping the installation. Perhaps you should install elsewhere and move the files manually.
            RonanR
            Same thing here... couldn't extract using WinZip. Ended up extracting using Stuffit instead, which I discovered was on my machine (1627 days of evaluation... woops).
            %(#BF00FF)[Please keep signatures minimal.
            Oh, and ditch incandescent light bulbs.]
              RonanR
              No, its Windows 'deciding' the content can be harmful... my Norton AV passes your zip file as clean... Perhaps the ability to download the installer Unzipped from Light-up.co.uk would help some people with the same problem? Just a thought.
              • I Offline
                ilay7k
                Adam maybe using of sfx(self-extracted exe...in your archive-tool's options) package for 2 files...
                Adam what about if somebody made scene and configured lightUp's options, and remotely sent to other...how to start rendering?
                for example your studio-file, i open and what i do to start simulation? when i push TourTool and there is no actions...then add AO and push TT, it works fine
                I forget to add that i register at lightUp's forum
                Sorry for my English ๐Ÿ˜ž
                  pmiller
                  Will not unzip on my computer either -- even after unchecking "unblock" in file properties and turning off anti-virus and firewall.
                  • Mike LuceyM Offline
                    Mike Lucey
                    Thanks Adam, everything opened fine. I've printed the instructions
                    and will read and have go tomorrow.
                    I really like the icons and way you have presented the package. Do
                    you use a Mac by any chance?
                    Mike
                    PS: Maybe you have done this already, I haven't checked on the forum.
                    Is there a Video Tutorial available showing a step by step approach?
                    • AdamBA Offline
                      AdamB
                      The lighting options etc are all stored with the .skp file so sending it to somebody else will retain that info. The lighting data is created locally and NOT currently saved with the skp file.
                      The TourTool checks to see whether you've created lighting data and only starts if you have. So creating either Ambient Occlusion or Direct lighting (or both!) will then allow TourToool to start.
                      Adam
                      • AdamBA Offline
                        AdamB
                        Mike
                        Thank you. Yes, I regularly use Macs and PCs though my main machine is a G5 Mac.
                        I will be posting some video tutorials. Any suggestions as to areas that would benefit most, would be much appreciated.
                        AdamB
                        • I Offline
                          ilay7k
                          Thank you for explanation
                          and when i modify geometry and some features in my scene, can i reset previous setting: remove LU-layer or something?
                          Thanks,
                          i move to LU's forum...is it open?
                          • AdamBA Offline
                            AdamB
                            Its the .msi file that is causing problems for JClements I believe so I'm not sure that would help.
                            I think there is bound to be a "learning experience" for me about the best way of packaging and downloading this stuff for minimal aggravation over the coming weeks!
                            • EdsonE Offline
                              Edson
                              @adamb said:
                              AdamB
                              adam,
                              no problems whatsoever downloading and installing LightUp in my mac.
                              i have started playing with it but, being a novice at rendering in general, it would be great to have a couple of tutorials or videos demonstrating a typical workflow. this will certainly allow us to make the best of LightUp.
                              a question: the time limit of 30 minutes means that everytime i open SU i have 30 min to use LU? what if a render takes more than that? if i am misunderstanding this please enlighten me.
                              it is difficult to navigate within the studio skippy you posted as there are no scenes set up. if one makes any false move the only way to get back to the scene is close and reopen the file.
                              congratulations on your effort.
                              edson mahfuz, architect| porto alegre โ€ข brasil
                              http://www.mahfuz.arq.br
                              • tbdT Offline
                                tbd
                                feedback:
                                • model that is in the manual should be added to get on track easily
                                • output bug: see attached (happened several times, cannot duplicate)
                                • better icons ๐Ÿ’š (too much antialias when Larg Icons is set)
                                • a way to disable the debug text from Ruby console
                                • in direct lighting do not apply sun if it is not selected
                                ideas:
                                • overlay on top of SU output with custom opacity - to have the lines visible
                                nice work Adam ๐Ÿ‘
                                lightup save image output
                                http://plugins.ro
                                • tbdT Offline
                                  tbd
                                  Juju: supersampling is not available in this version
                                  http://plugins.ro
                                  • jujuJ Offline
                                    juju
                                    Makes sense then, thx TBD.
                                    Also, the room scale (studio2.skp file) seems to off quite a bit. I use the position camera and point to a place on the floor, eye height set to 5'6" and I'm virtually as tall as the room.
                                    • jujuJ Offline
                                      juju
                                      I get this error message when I press the LightUp prefences button.
                                      If you press "yes" you can continue onto the settings window, but supersampling cannot be enabled.
                                      • AdamBA Offline
                                        AdamB
                                        @edson said:
                                        @adamb said:
                                        AdamB
                                        adam,
                                        Generally LightUp rendering is pretty quick (obviously it depends on the model complexity) so 30 minutes seemed reasonable to give people a go with the technology to see if its useful to them. I've certainly added onto the TODO list something to allow you to quit from rendering if its taking too long - or there's a bug causing LightUp to spin endlessly.
                                        As to getting lost in studio2.skp Yes, it was modelled with no scale in mind hence the crazy dimensions. However, you can control the speed of the camera motion in LightUp from the Preferences dialog. In "Viewing" look for "Speed". Also, if you ever get lost anywhere in Sketchup, Apple/Ctrl-1 to reset the camera position is always helpful.
                                        Adam
                                        • AdamBA Offline
                                          AdamB
                                          Correct! And I have a question mark as to its usefulness too. Currently its a rotating multi-tap kernel but I'm thinking you might as well just turn up the Resolution of the lighting to achieve much the same effect.
                                          Adam
                                          • AdamBA Offline
                                            AdamB
                                            feedback:
                                            Yes, for the actual release there will be examples, videos etc.
                                            I have had some OpenGL drivers create odd snapshots. Try adjusting the size of the window (which will in turn change the size of the output size.)
                                            Yep, I plan to. Left it in for now since it doesn't do much harm. But yes I agree.
                                            Can you explain. "Use sun" is selected by default. If you turn it off, LightUp shouldn't use the Sun.
                                            ideas:
                                            Hmm. I have the greatest respect for the SU developers, but there OpenGL backend is the slowest thing I have ever seen. I don't know what goes on behind the scenes, but anything I can do to get as far away from it is going to help performance. If there is real call for lines - I'll draw 'em!
                                            nice work Adam ๐Ÿ‘
                                            Thank you. Fair amount of work to do yet!
                                            Adam
                                            • 11
                                            • 12
                                            • 7 / 12
