    [Tutorial] Create a (TIN) from Surveyed Pts - using SU only
    32 Posts 15 Posters 29.6k Views 15 Watching
    • H
      Howard leslie
      See attached
      A simple method to create a Surface (TIN) from Svy Symbols / Points using SU only.
      (Typically imported from a CAD file)
      This method works well for relatively few points
      Scripts reqd:
      points_cloud_triangulation.rb
      delauney2.rb
      Work together - get latest versions
      Download from here:
      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
      Thank you Didier.
      Centrepoint.rb
      Download from here:
      http://www.smustard.com/scripts/
      Thank you Todd.
      Produced in response to following request:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=4240
      Note:
      X,Y,Z coordinates of surveyed points from text files / spreadsheets can also be imported into SU using different methods / scripts - this is especially useful if you have large numbers of points.
      Howard L'
      SvySymbol_2_Surface_V2.skp
      • M
        Mr S
        Thanks,
        Much appreciated.
        Regards
        Mr S
        • GaieusG
          Ah yes, I was too late to reply in the other thread... 😄
          Howard, really kind of you (as usual, I could say...)
          • GaieusG
            Have you got delauney2.rb also installed into your plugins folder? (It is required with this script).
            If not, see this post:
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=4134
            • GaieusG
              I cannot help you now from the office since I have a new install of SU without practically any rubies. I1ll see what I can do at home - or why not start a thread in the ruby discussion and Didier would surely drop in?
              • T
                todd burch
                Edit the point_cloud script to remove the ./ from in front of the delauney.rb name.
                Todd
                • A
                  azuby
                  Open a simple Editor (not Word! It is NOT simple 😉 ). You can find one in Start > Programs > "Zubehör" (sorry, don't know how it is named in English) > Editor. Open the file "points_cloud_triangulation.rb", search for "./delauney2.rb" and remove "./" Save the file. You're done.
                  azuby
                  • T
                    todd burch
                    I would suggest using Notepad.
                    • GaieusG
                      Yes, most probably.
                      Now create a bunch of construction points, select them and run the script.
                      • GaieusG
                        How big is that file?
                        • tinanneT
                          tinanne
                          This is great information. I could have really used this last month when I was pulling my hair out tracing contour lines and raising each individual line AND THEN trying to mesh them together!
                          This is great!
                          Executive Director : American Society of Architectural Illustrators
                          AIP 30 Competition opens soon. ASAI.org
                          Architectural Rendering
                          • GaieusG
                            James,
                            I have sent you an email, please, confirm the delivery...
                            • GaieusG
                              My problem was that the cad file didn't show up when imported 😒.
                              Yes because all the Layers were turned off and nothing was on Layer0 😆
                              I could hardly find those crosses anyway.
                              But now you are really in big problem because moving those points to the proper height will be very tedious. There are some 1800 of the (or 1300?) altogether. And you'll need to re-run the script too.
                              • A
                                andymaw
                                Have you had any joy? I'm in exactly the same boat. A number of spot heights (not quite 1300 though!) all in 2d, trying to create an accurate terrain in sketchup
                                • GaieusG
                                  Can you not get the xyz coordinates as just a data file? Those guys must have worked with something as well!
                                  • AnssiA
                                    Anssi
                                    Depending on the type of the information in the DWG, it might not be very difficult to write an AutoLisp routine that would scan a DWG file for points or text entities, and replace them with some small geometric entity (a line, or cross etc.)at the correct height, that could be imported into SU and sandboxed into a TIN.
                                    Anssi
                                    • J
                                      jmqrsq
                                      Scripts reqd:
                                      delauney2.rb
                                      Download from here:
                                      Thank you Didier.
                                      I have tried to download the delaunay2.rb script but the links do not work anywhere. can someone send it to me? i can provide an email addy. thanks!
                                      • AnssiA
                                        Anssi
                                        So ur saying Anssi that a 2D drawing with points, which is what I have, could be changed into a 3D drawing. That would save alot of work. Can that be done? The Z value would have to be added to each point though, and there are 1300! 😒
                                        It depends on how the 3D information is displayed in the file. For instance, I have seen many site surveys with the height information as simple text objects strewn around the map, or the height is in an attribute of a block. In both these cases it is possible to grab the 2D coordinates of the object, and use the text contents for the Z information, and draw something there that is importable to SU. A sort of "unflatten" operation. Of course the requirement is that the information is there in some consistent form.
                                        Anssi
                                        • GaieusG
                                          There is a confusion (probably due to a typo somewhere) because this script sometimes is referred as "delaunay.rb" while other times as "delauney.rb".
                                          Here is a post where lapx aslo asked for the delauney.rb (which I believe the proper name is) and I posted a copy of it.
                                          Try that, hope it works.
                                          • E
                                            eugenesr
                                            Here is the file location of the script:
                                            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/delaunay.rb
                                            and here is the Ruby Script Index page http://www.crai.archi.fr/RubyLibraryDepot/Ruby/
                                            Eugene
                                            /Fire Fighter! Funny job for an artist, no?/
                                            HP laptop running XP
