    [Tutorial] Create a (TIN) from Surveyed Pts - using SU only
    32 Posts 15 Posters 28.8k Views 15 Watching
      Have you got delauney2.rb also installed into your plugins folder? (It is required with this script).
      If not, see this post:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=4134
        I cannot help you now from the office since I have a new install of SU without practically any rubies. I1ll see what I can do at home - or why not start a thread in the ruby discussion and Didier would surely drop in?
          todd burch
          Edit the point_cloud script to remove the ./ from in front of the delauney.rb name.
          Todd
            azuby
            Open a simple Editor (not Word! It is NOT simple 😉 ). You can find one in Start > Programs > "Zubehör" (sorry, don't know how it is named in English) > Editor. Open the file "points_cloud_triangulation.rb", search for "./delauney2.rb" and remove "./" Save the file. You're done.
            azuby
            *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
            Bad English? PM me, correct me. :smile:**
              todd burch
              I would suggest using Notepad.
                Yes, most probably.
                Now create a bunch of construction points, select them and run the script.
                  How big is that file?
                  • tinanneT Offline
                    tinanne
                    This is great information. I could have really used this last month when I was pulling my hair out tracing contour lines and raising each individual line AND THEN trying to mesh them together!
                    This is great!
                    Executive Director : American Society of Architectural Illustrators
                    AIP 30 Competition opens soon. ASAI.org
                    Architectural Rendering
                      James,
                      I have sent you an email, please, confirm the delivery...
                        My problem was that the cad file didn't show up when imported 😒.
                        Yes because all the Layers were turned off and nothing was on Layer0 😆
                        I could hardly find those crosses anyway.
                        But now you are really in big problem because moving those points to the proper height will be very tedious. There are some 1800 of the (or 1300?) altogether. And you'll need to re-run the script too.
                          andymaw
                          Have you had any joy? I'm in exactly the same boat. A number of spot heights (not quite 1300 though!) all in 2d, trying to create an accurate terrain in sketchup
                            Can you not get the xyz coordinates as just a data file? Those guys must have worked with something as well!
                            • AnssiA Offline
                              Anssi
                              Depending on the type of the information in the DWG, it might not be very difficult to write an AutoLisp routine that would scan a DWG file for points or text entities, and replace them with some small geometric entity (a line, or cross etc.)at the correct height, that could be imported into SU and sandboxed into a TIN.
                              Anssi
                                jmqrsq
                                Scripts reqd:
                                delauney2.rb
                                Work together - get latest versions
                                Download from here:
                                http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                                Thank you Didier.
                                I have tried to download the delaunay2.rb script but the links do not work anywhere. can someone send it to me? i can provide an email addy. thanks!
                                • AnssiA Offline
                                  Anssi
                                  So ur saying Anssi that a 2D drawing with points, which is what I have, could be changed into a 3D drawing. That would save alot of work. Can that be done? The Z value would have to be added to each point though, and there are 1300! 😒
                                  It depends on how the 3D information is displayed in the file. For instance, I have seen many site surveys with the height information as simple text objects strewn around the map, or the height is in an attribute of a block. In both these cases it is possible to grab the 2D coordinates of the object, and use the text contents for the Z information, and draw something there that is importable to SU. A sort of "unflatten" operation. Of course the requirement is that the information is there in some consistent form.
                                  Anssi
                                    There is a confusion (probably due to a typo somewhere) because this script sometimes is referred as "delaunay.rb" while other times as "delauney.rb".
                                    Here is a post where lapx aslo asked for the delauney.rb (which I believe the proper name is) and I posted a copy of it.
                                    Try that, hope it works.
                                    • E Offline
                                      eugenesr
                                      Here is the file location of the script:
                                      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/delaunay.rb
                                      and here is the Ruby Script Index page http://www.crai.archi.fr/RubyLibraryDepot/Ruby/
                                      Eugene
                                      /Fire Fighter! Funny job for an artist, no?/
                                      HP laptop running XP
                                        andymaw
                                        Not been able to check on this for a while....
                                        I've had a look at the drawing full of spot heights that I have and they are all at the correct z value....however, it is just text, not crosses etc.
                                        Is there a quick way to create these crosses where the text is? I had a look at that autolisp, it looks mind boggling!
                                        • AnssiA Offline
                                          Anssi
                                          This might be a bit OT as you need AutoCad...
                                          I took an old Autolisp program I once made and modified it to do this:
                                          Scan a selection for text entities. Read the text and convert it to a number and multiply it with an user supplied factor (for unit conversions). Draw a line from the text insertion point to the text upper right corner, using the text as the Z height of the line endpoints. Repeat until all texts in the selection have been processed.
                                          The result should be a cloud of small lines that the SU Sandbox from Contours tool can cover with a surface.
                                          How it works:
                                          • copy the txt23d.lsp file somewhere where Autocad can find it. It should work if put in the same directory as the drawing file to process.
                                          • type (load "txt23d") to the AutoCad command line and press Enter
                                          • type txt23d and Enter
                                          • It asks the user for a selection
                                          • It asks the user for a Z scale factor
                                          Disclaimer: The lisp has almost none error checking. Scale factor should reset itself to 1 if you forget to give one. It's not rocket science - the real height point may be not exactly at the text insertion.
                                          Anssi
                                          TXT23D.zip
                                            andymaw
                                            That did the job! Thanks so much for that. Just got to find the time to put the guide points into SU and it should be sorted.
                                            Cheers again
