    License File
    6 Posts 2 Posters 1.7k Views 2 Watching
    • C
      cjlopez4
      We recently changed servers at the office and the server name has changed which gives me an license error? How can I fix this? The error reads: "The server.dat specifies a sketchup license file that does not exist or is currently unaccesible...."
      • GaieusG
        Have you re-activated the SU license on the new server?
        • C
          cjlopez4
          How do I reactivate? I try and update the lic within Su, however the option is greyed out.
          • GaieusG
            OK, I think I've found some info.
            1. Make sure that all SU instances on your network run the current (latest) version of SU
            2. Then go to this page and check out if anything applies to you.
            3. But most probably this is your solution.
            I hope it helps...
            • C
              cjlopez4
              #3 did the trick, thanks.
              • GaieusG
                Good, glad to hear that.
                πŸ˜„
