    Two Radius intersecting at 90 degrees
    32 Posts 9 Posters 4.0k Views 9 Watching
      Dylan, see the thread about Camtasia (free now) here.
      πŸ˜’
        dylan
        How did I miss that thread!
        Ok, well if you follow the link Gaieus posted, it says the offer has expired on the webpage.
        Ignore it!
        Just click on the link to download the program then the link to get your serial. On this page it tells you the offer ends 7th January.
        2 days to grab it!
        http://dmdarchitecture.co.uk/
        • G Offline
          Gidon Yuval
          Am I too late to offer this little tut?
          Testing2.skp
          If you don't know where you're going, you're never going to get there.
            Yes, Gidon, too late. (Of course when someone is cooking goulash on Sabbath! πŸ˜„ )
            See this post with this attachment.
            πŸ˜„
              Julius
              check out Debut, it's better tahn autoscreenrecorder purchasable version and it's free. (when installing it will ask you if you want to install any other program, they're all trial versions but "Prism" wich is free and is a good video format converter).
              • G Offline
                gata
                On the original model, that 'stubborn' face would have pushed through if you used Push/Pull+Ctrl (PC).
                • N Offline
                  natemclain
                  I was just able to get back on the PC and play with this some more.
                  I have a new problem...
                  Just so you know this is a leg for furniture.
                  I can make the leg by hand, but want to share it with others online.
                  I have the profile that I want to push to the back side on both faces of the model.
                  Can someone explain the process to accomplish this?
                  Should I push/pull the curved profile back before I create the cove on the 2 faces that everyone has shown?
                  All the suggestions have been very helpful! And I have learned allot with this excercise.
                  BTW I have attached an actual picture of the leg that I'm trying to model.
                  TIA
                  Nate
                  TestingAgain.skp
                    Hi Nate,
                    Have a look at Gidon's "Cabriole leg" tutorial in this thread to get some ideas.
                    This leg of yours have some similarities and you can easily adapt the workflow.
                    • P Offline
                      PKast
                      Here's your answer. Follow along by clicking on the tabbed scenes.
                      There are some tutorials on just this type of leg. Try a search on cabriole leg.
                      Best
                      PKastmiler
                      TestingAgain[1] Answer.skp
                        Holy crap, I didn't even notice the skp attachment below the image!
                        Great solution, PKast!
                        • N Offline
                          natemclain
                          You guys are absolutely amazing!
                          Works great.
                          Thanks for the tips.
                          This software is incredible!
                          Thanks again!
                          Nate
                          • P Offline
                            Pagan
                            http://i3.tinypic.com/6tzdekj.jpg
                            If the rear side have same shape as front side of leg you could do it like this.
                            Video preview:http://dhost.info/pagan/leg.avi
                            And here is a model:http://dhost.info/pagan/leg.skp
                            • 2 / 2
