    [Plugin] Cutting Windows script
    27 Posts 13 Posters 40.9k Views 13 Watching
      Perhaps it's time to look up my 'HolePunchTool' [ http://forums.sketchucation.com/viewtopic.php?p=271170#p271170 ] which does a similar job BUT has far more bells and whistles - and works relatively seamlessly and has had few error reports...
      • P Offline
        paddyclown
        TIG, yes, thanks, actually I have been trying to use your tool, but sadly it doesn't work for some unknown reason... I followed the instructions which seem pretty clear & can't get it to work 😞
        I have made a component that glues to "any" & has cut opening checked but when i try & use it (ie it is in place on a face of a 'wall' & i r-click & choose punch ) I get this message 'no suitable punching component selected, exiting'... maybe i have just not understood the procedure
        file test
        • P Offline
          paddyclown
          ... sorry i pressed the submit button too fast...
          Thanks for any guidance..
          best
          screenshot
            Your cutting component is not made properly its axes are the wrong way round.
            It's clear from the Component's thumbnail in the Component Browser which is looking at the 'top' of it and not the 'front', as it should for any 'cutting' door/window/etc
            When you make any 'cutting component' it must either be made 'flat' on the ground or already on a face.
            If it's made on a face Sketchup assumes you want it to be 'cutting' and it sorts out the axes for you. Otherwise make it so that its z/blue axis will be facing square out of any face you might subsequently place it on.
            A cutting component's axes look different from a standard component as there's a blue 'X' added to it
            Then when you place your properly made cutting component on a face it should cut a hole in that face - so any transparent or open areas will be 'see-through' - if the wall has two faces you'll see the back-face of the other side.
            If you then use my HolePunchTool on the component it punches through the inner face too, adding linked reveals etc...
            Here's your component fixed and a version punched...
            Compare it with the original...Capture.PNGhole punch test [fixed].skp
            • P Offline
              paddyclown
              😳 ok, sorry, just tried for myself & got it finally sorted...
              thanks for your help TIG
              • sandropasquaS Offline
                sandropasqua
                Hi Didier,
                I'm sorry but i cannot see the command line in the right clic menu...
                I've tried with two component
                Do you have any suggestion?
                ThanksWindows cut test.skp
                  jabrown
                  the windows isn't cutting holes in the walls after installed.
                  • 2 / 2
