    [Plugin] Cutting Windows script
    27 Posts 13 Posters 41.7k Views 13 Watching
    • Didier BurD Offline
      Didier Bur
      Kmead: I've PM'ed you an updated script. Tell me if it works.
      Cheers,
      DB
        Ben Ritter
        Thank you for your generosity.
          amadex
          @kmead said:
          Didier:
          Many thanks for what I hope becomes another great tool. I ran into the attached problem at startup of SU after installing your new ruby.
          I am on a Mac, OSX 10.4.11 with a PPC chip. I will check on my Intel Mac tomorrow after I get back to work.
          All the best.
          Karl
          Hi Didier, it happens the same with me... How can I solve this?
          tkx
            Didier Bur
            @ Amadex: look at the top of this topic, I've released a Mac version.
            Tell me if it's OK.
            DB
              gerdwillemen
              Didier
              I also tried your "mac version. I also get an "error" report.
              Could you help ?
              See error report in attachment
              Gerd
              • mariochaM Offline
                mariocha
                Just to let you know that the Mac version works fine here.
                The whole thing is a 3 step process;
                1. define as cutting window
                2. put it on a wall
                3. right-click window and select "Cut wall from window" then parameters.
                  Also works on several windows at a time.
                  Many well deserved thanks to the author !
                %(#008000)[Mario C.
                  paddyclown
                  I tried to add this plugin to SUv8 Pro & got this message:
                  Error Loading File cutting_windows.rb
                  (eval):719: compile error
                  (eval):610: syntax error, unexpected ',', expecting kEND
                  faces_and_heights[0].pushpull (faces_and_heights[1]), false
                  ^Error Loading File yaml.rb
                  no such file to load -- date
                  Does anyone have an idea what is going on ?
                  Thanks in advance folks,
                    Perhaps it's time to look up my 'HolePunchTool' [ http://forums.sketchucation.com/viewtopic.php?p=271170#p271170 ] which does a similar job BUT has far more bells and whistles - and works relatively seamlessly and has had few error reports...
                      paddyclown
                      TIG, yes, thanks, actually I have been trying to use your tool, but sadly it doesn't work for some unknown reason... I followed the instructions which seem pretty clear & can't get it to work 😞
                      I have made a component that glues to "any" & has cut opening checked but when i try & use it (ie it is in place on a face of a 'wall' & i r-click & choose punch ) I get this message 'no suitable punching component selected, exiting'... maybe i have just not understood the procedure
                      file test
                        paddyclown
                        ... sorry i pressed the submit button too fast...
                        Thanks for any guidance..
                        best
                        screenshot
                          Your cutting component is not made properly its axes are the wrong way round.
                          It's clear from the Component's thumbnail in the Component Browser which is looking at the 'top' of it and not the 'front', as it should for any 'cutting' door/window/etc
                          When you make any 'cutting component' it must either be made 'flat' on the ground or already on a face.
                          If it's made on a face Sketchup assumes you want it to be 'cutting' and it sorts out the axes for you. Otherwise make it so that its z/blue axis will be facing square out of any face you might subsequently place it on.
                          A cutting component's axes look different from a standard component as there's a blue 'X' added to it
                          Then when you place your properly made cutting component on a face it should cut a hole in that face - so any transparent or open areas will be 'see-through' - if the wall has two faces you'll see the back-face of the other side.
                          If you then use my HolePunchTool on the component it punches through the inner face too, adding linked reveals etc...
                          Here's your component fixed and a version punched...
                          Compare it with the original...Capture.PNGhole punch test [fixed].skp
                            paddyclown
                            😳 ok, sorry, just tried for myself & got it finally sorted...
                            thanks for your help TIG
                            • sandropasquaS Offline
                              sandropasqua
                              Hi Didier,
                              I'm sorry but i cannot see the command line in the right clic menu...
                              I've tried with two component
                              Do you have any suggestion?
                              ThanksWindows cut test.skp
                                jabrown
                                the windows isn't cutting holes in the walls after installed.
                                • 2 / 2
