    [Plugin] Cutting Windows script
    27 Posts 13 Posters 39.7k Views 13 Watching
    • Didier BurD Offline
      Didier Bur
      Hope you find it useful... 😄
      Bug(s) ? Comment(s) ? idea (s) ? Feel free to report.
      Edit: PATCHED ON 12.31.07 (bug fix) 😳
      English version. WINDOWS VERSION. Unzip in Plugins folder. PDF doc included.
      Version française. Dezipper dans le dossier Plugins. Doc PDF incluse.
      MAC VERSION
      DB
      • CadFatherC Offline
        CadFather
        Thanks Didier - i get this:
        Error Loading File Cutting_Windows.rb
        C:/Program Files/Google/Google SketchUp 6/Plugins/Cutting_Windows.rb:1: Invalid char `\003' in expression
        i downloaded with dialup so i cannot rule out the fault being somewhere in the process..
        • jenujacobJ Offline
          jenujacob
          didier,
          i loaded the .rb into the plugins folder... but however i do not get the right click option 'Window And Wall'...
          any thoughts?
          • I Offline
            ilay7k
            Thank you!
            @jenujacob said:
            didier,
            any thoughts?
            I have too...
            open component...define face and nothing in right-click action
              Didier Bur
              Below is the code of the controling function to wether display menu or not.
              So, if you're not satisfying all the uppercase comments, it is normal that you don't have the item in the context menu.
              Please let me know 😳
              def check_selection_floating_component
              sel = Sketchup.active_model.selection
              return false if sel.length != 1 #ONE ITEM SELECTED AT A TIME
              return false if sel[0].typename != "ComponentInstance" #MUST BE A COMPONENT INSTANCE
              f = sel[0].glued_to
              behavior = sel[0].definition.behavior.snapto
              if not f and behavior != 0 # IF COMPO IS NOT GLUED TO A FACE (FLOATING) AND IF COMPONENT CANNOT BE GLUED TO "NONE"
                return true #LET'S GO FOR THE MENU
                else
                return false #DON'T DISPLAY ITEM IN CONTEXT MENU
              DB
                jenujacob
                SO BASICALLY..
                1. only one component has to be selected.... yes.
                2. must be a component instance... which means ????
                3. the component is not glued to a face... yes this is also satisfied..
                still nothin in the context menu.... or am i missing something from the code???? 😳
                ive never in my life even tried to read a code.. please forgive my ignorance!!! 😄 😉
                  Didier Bur
                  Hi Jenujacob,
                  Please post the SKP so I can test what's happening. Maybe this has something to do with the model settings, 'cause you're doing everything right.
                  DB
                    jenujacob
                    well theres nothing special in this skp though... its just has a standard "window" component from the architecture library placed in empty space as told in the PDF tutorial u provided..
                    Untitled.skp
                    i am also attaching a jpg showing the plugin placement.. just in case...
                    • I Offline
                      ilay7k
                      Didier, thanks a'lot!
                      It works! I just use componets from my collection and sketchup libraries(with glue allways)...so i play with glue function in comp-t's options(turn on any, sloped and ect...then back to none) and wall-cutting options appear in context-menu...slow response that component was unglued
                      Ohhh....we can put comp-ts at wall and ect. then manupulate with detail cutting
                      Thanks! Happy New Year!
                        Didier Bur
                        Thanks ilay7k for tracking bugs...
                        Patched on 12.31.07 13:40 PM (GMT+2) ❗
                        Didn't work with components that had a behavior not to glue to anything.
                        Now works with every kind of component.
                        Happy new year !
                        DB
                        • I Offline
                          ilay7k
                          Happy new year !
                          It lives...works! 😲 😄
                          Thanks!
                          future of 2008
                          +dynammic any!!
                            jenujacob
                            this is awesome!!! thanks didier!!! 😄
                            happy new year!!!
                            • kmeadK Offline
                              kmead
                              Didier:
                              Many thanks for what I hope becomes another great tool. I ran into the attached problem at startup of SU after installing your new ruby.
                              I am on a Mac, OSX 10.4.11 with a PPC chip. I will check on my Intel Mac tomorrow after I get back to work.
                              All the best.
                              Karl
                              I created Dilbertville, sorry about that...
                                Didier Bur
                                Kmead: I've PM'ed you an updated script. Tell me if it works.
                                Cheers,
                                DB
                                  Ben Ritter
                                  Thank you for your generosity.
                                    amadex
                                    @kmead said:
                                    Didier:
                                    All the best.
                                    Karl
                                    Hi Didier, it happens the same with me... How can I solve this?
                                    tkx
                                      Didier Bur
                                      @ Amadex: look at the top of this topic, I've released a Mac version.
                                      Tell me if it's OK.
                                      DB
                                      • G Offline
                                        gerdwillemen
                                        Didier
                                        I also tried your "mac version. I also get an "error" report.
                                        Could you help ?
                                        See error report in attachment
                                        Gerd
                                        • mariochaM Offline
                                          mariocha
                                          Just to let you know that the Mac version works fine here.
                                          The whole thing is a 3 step process;
                                          1. define as cutting window
                                          2. put it on a wall
                                          3. right-click window and select "Cut wall from window" then parameters.
                                            Also works on several windows at a time.
                                            Many well deserved thanks to the author !
                                          %(#008000)[Mario C.
                                          • P Offline
                                            paddyclown
                                            I tried to add this plugin to SUv8 Pro & got this message:
                                            Error Loading File cutting_windows.rb
                                            (eval):719: compile error
                                            (eval):610: syntax error, unexpected ',', expecting kEND
                                            faces_and_heights[0].pushpull (faces_and_heights[1]), false
                                            ^Error Loading File yaml.rb
                                            no such file to load -- date
                                            Does anyone have an idea what is going on ?
                                            Thanks in advance folks,
                                            • 1 / 2
