    [Plugin] Cutting Windows script
    27 Posts 13 Posters 41.0k Views 13 Watching
    • jenujacobJ Offline
      jenujacob
      didier,
      i loaded the .rb into the plugins folder... but however i do not get the right click option 'Window And Wall'...
      any thoughts?
      • I Offline
        ilay7k
        Thank you!
        @jenujacob said:
        didier,
        any thoughts?
        I have too...
        open component...define face and nothing in right-click action
        • Didier BurD Offline
          Didier Bur
          Below is the code of the controling function to wether display menu or not.
          So, if you're not satisfying all the uppercase comments, it is normal that you don't have the item in the context menu.
          Please let me know 😳
          def check_selection_floating_component
          sel = Sketchup.active_model.selection
          return false if sel.length != 1 #ONE ITEM SELECTED AT A TIME
          return false if sel[0].typename != "ComponentInstance" #MUST BE A COMPONENT INSTANCE
          f = sel[0].glued_to
          behavior = sel[0].definition.behavior.snapto
          if not f and behavior != 0 # IF COMPO IS NOT GLUED TO A FACE (FLOATING) AND IF COMPONENT CANNOT BE GLUED TO "NONE"
            return true #LET'S GO FOR THE MENU
            else
            return false #DON'T DISPLAY ITEM IN CONTEXT MENU
          DB
            jenujacob
            SO BASICALLY..
            1. only one component has to be selected.... yes.
            2. must be a component instance... which means ????
            3. the component is not glued to a face... yes this is also satisfied..
            still nothin in the context menu.... or am i missing something from the code???? 😳
            ive never in my life even tried to read a code.. please forgive my ignorance!!! 😄 😉
              Didier Bur
              Hi Jenujacob,
              Please post the SKP so I can test what's happening. Maybe this has something to do with the model settings, 'cause you're doing everything right.
              DB
                jenujacob
                well theres nothing special in this skp though... its just has a standard "window" component from the architecture library placed in empty space as told in the PDF tutorial u provided..
                Untitled.skp
                i am also attaching a jpg showing the plugin placement.. just in case...
                • I Offline
                  ilay7k
                  Didier, thanks a'lot!
                  It works! I just use componets from my collection and sketchup libraries(with glue allways)...so i play with glue function in comp-t's options(turn on any, sloped and ect...then back to none) and wall-cutting options appear in context-menu...slow response that component was unglued
                  Ohhh....we can put comp-ts at wall and ect. then manupulate with detail cutting
                  Thanks! Happy New Year!
                    Didier Bur
                    Thanks ilay7k for tracking bugs...
                    Patched on 12.31.07 13:40 PM (GMT+2) ❗
                    Didn't work with components that had a behavior not to glue to anything.
                    Now works with every kind of component.
                    Happy new year !
                    DB
                    • I Offline
                      ilay7k
                      Happy new year !
                      It lives...works! 😲 😄
                      future of 2008
                      +dynammic any!!
                        jenujacob
                        this is awesome!!! thanks didier!!! 😄
                        happy new year!!!
                        • kmeadK Offline
                          kmead
                          Didier:
                          Many thanks for what I hope becomes another great tool. I ran into the attached problem at startup of SU after installing your new ruby.
                          I am on a Mac, OSX 10.4.11 with a PPC chip. I will check on my Intel Mac tomorrow after I get back to work.
                          All the best.
                          Karl
                          I created Dilbertville, sorry about that...
                            Didier Bur
                            Kmead: I've PM'ed you an updated script. Tell me if it works.
                            Cheers,
                            DB
                              Ben Ritter
                              Thank you for your generosity.
                                amadex
                                @kmead said:
                                Didier:
                                All the best.
                                Karl
                                Hi Didier, it happens the same with me... How can I solve this?
                                tkx
                                  Didier Bur
                                  @ Amadex: look at the top of this topic, I've released a Mac version.
                                  Tell me if it's OK.
                                  DB
                                    gerdwillemen
                                    Didier
                                    I also tried your "mac version. I also get an "error" report.
                                    Could you help ?
                                    See error report in attachment
                                    Gerd
                                    • mariochaM Offline
                                      mariocha
                                      Just to let you know that the Mac version works fine here.
                                      The whole thing is a 3 step process;
                                      1. define as cutting window
                                      2. put it on a wall
                                      3. right-click window and select "Cut wall from window" then parameters.
                                        Also works on several windows at a time.
                                        Many well deserved thanks to the author !
                                      %(#008000)[Mario C.
                                        paddyclown
                                        I tried to add this plugin to SUv8 Pro & got this message:
                                        Error Loading File cutting_windows.rb
                                        (eval):719: compile error
                                        (eval):610: syntax error, unexpected ',', expecting kEND
                                        faces_and_heights[0].pushpull (faces_and_heights[1]), false
                                        ^Error Loading File yaml.rb
                                        no such file to load -- date
                                        Does anyone have an idea what is going on ?
                                        Thanks in advance folks,
                                          Perhaps it's time to look up my 'HolePunchTool' [ http://forums.sketchucation.com/viewtopic.php?p=271170#p271170 ] which does a similar job BUT has far more bells and whistles - and works relatively seamlessly and has had few error reports...
                                            paddyclown
                                            TIG, yes, thanks, actually I have been trying to use your tool, but sadly it doesn't work for some unknown reason... I followed the instructions which seem pretty clear & can't get it to work 😞
                                            I have made a component that glues to "any" & has cut opening checked but when i try & use it (ie it is in place on a face of a 'wall' & i r-click & choose punch ) I get this message 'no suitable punching component selected, exiting'... maybe i have just not understood the procedure
                                            file test
