    [Tutorial > Modeling] A Cube with Radiused Edges
    28 Posts 14 Posters 16.4k Views 14 Watching
    • mitcorbM Offline
      mitcorb
      I remember vaguely, that someone showed that you could create the round corner cube using the perimeter of a filleted square lying on the ground plane xy, as the followme path and place the same thing vertically and centered above it. Select only the edge of the ground plane object and click follow me on the face of the square above it. In fact, I just did it. I made the fillet corners with TIG's 2dtools fillet.
      • jeff hammondJ Offline
        jeff hammond
        that sort of works but you still run into the follow me error..
        check the skp:
        doing_it_like_that.skp
        (this is the same problem as trying to offset a radius in sketchup. the end segments are treated as single lines instead of being considered as part of an arc)
        dotdotdot
          Well, I'd also use the plugin now just wanted to teach somebody how to do it with the native tools first (the "prize" was that I showed the plugin after the success).
          You know guys that I am "old school" from certain points. Best is to master SU first of all and then become lazy and use the plugins.
          • mitcorbM Offline
            mitcorb
            I examined my skp and after scaling it up 10x, zooming almost to clipping, I noticed a chevron shaped overlapping condition at the top and bottom faces of the cube at each corner with hard line edges. Selecting and deleting an edge resulted in the adjacent face disappearing. Going a little further with stitching vertices closed the open faces. Obviously, the closure did not result in uniform "contours". However, I did get closure, and I presume, watertight.
            So, some "error" does still occur, but in my case, not a residual open face--unless I did not scale up enough.
              Those little chevron-shaped faces are common with Follow Me when you run a profile around an arc of the same or smaller radius. If you scale up, select all of the neighboring geometry and then run Intersect Faces>With Selection, you can safely delete those faces and the unneeded edges without losing the adjoining faces.
              It occurred to me some time ago that what is happening is similar to what happens when you wrap a piece of packaging tape around a similar shape. You'll get little flags sticking up. It's also similar to what happens to a bed sheet at the corners of a mattress but you don't cut off the sheet; you just make hospital corners.
              • mitcorbM Offline
                mitcorb
                Yeah, I know about hospital corners. 😒 My wife is a healthcare professional. Maybe sketchup needs a hospital corner plugin 💚
                  jeff hammond
                  fwiw, the error always happens.. it's just more noticeable in situations where the profile length is equal to (or longer than) the radius..
                  i expect something like that to happen when the profile is longer than the radius but it should not happen when it's equal to or less than the radius..
                  the problem lies in the fact that sketchup uses segments instead of [math based curves].. i understand that it's nearly impossible (or absolutely impossible?) for sketchup to determine where a straight segment begins to blend to a curved section.. it can only see it as a kink.
                  however, i think if the curved section is recognized by SU as an arc then it should be able to deal with it in a proper manner but it still fails..
                  here's a skp showing what goes wrong:
                  camo style 🙂
                  this same error happens over and over with quite a few tools/plugins.. sketchup, as far as i'm concerned, is extremely accurate but anything dealing with offsets (the followme tool for instance, is making offset lines) is where sketchup falls flat on it's face (if accuracy is key).. this single flaw is what led me to begin learning a nurbs based app a year or two ago..
                  i still do most of my designs in sketchup (and actually, a roughed out version of the more difficult stuff happens first in sketchup) but when it comes time to do construction drawings for the more complex curved based structures, i go to nurbs..
                  it's a pretty good setup actually 😉
                  [EDIT- well, i might of said that wrong.. i use sketchup for quite a bit of the complex stuff as well but i stay away from the and as well as any of the methods that will generate these errors.. often leading to a bit more drawing time but it's worth it]
                  dotdotdot
                  • gillesG Offline
                    gilles
                    Here is my way to avoid this:
                    Cube_with_Radiused_Edges.skp
                    • 2 / 2
