    Xxx.skp does not exist !
    5 Posts 3 Posters 1.8k Views 3 Watching
    • A
      anglaret
      Hello
      This is the message I get when I want to save on a specific folder.
      Everything was going all right for monthes till I find myself not able to save on that folder.
      On a Vista laptop I created a partition (k:) where I put all my datas; since last week SU refuse to save on that folder, but accept all sub-folders of it. The properties of the folder are valid and comparable to all the sub-folders.
      I suspect Vista and its octopus security system , but I cannot find a solution.
      A help would be very much welcomed.
      Marc
      • B
        basic.woodworks
        @anglaret said:
        Hello
        Marc
        Did you ever solve this issue?? If so... what was the solution? If not, what other avenues have you tried and can you provide additional info??
        Mike RL
        "The greatest mistake a person can make is to be afraid of making one." (Elbert Hubbard)
        • Chris FullmerC
          Mike, are you having problems with this? I was thinking this was part of a bug that was fixed when SU finally came out with full Vista support, or maybe a patch after that or something. I'm not sure about that, but its what I think I remember.
          Chris
          All my Plugins I've written
          • B
            basic.woodworks
            Hey Chris
            No I'm not. I actually don't quite have a handle on your issue. I was looking through some of the older posts and fielding questions. (killing time). I saw yours and was curious to see if this was still an issue or not. If it is, maybe If I knew the full nature of the problem and some additional info as what you tried to fix it or if you did fix it, perhaps if you posted the results maybe, if someone else had a similar problem, it could help "them".
            Just trying to lend a helping hand.
            Mike RL
            • Chris FullmerC
              Thanks Mike, its not actually my issue though, the initial person who posted was someone else. I saying that I think their problem was cured in a new patch released by SU a while back. Then I was asking you if you had a similar problem, or if you were just trying to help troubleshoot. So I see you're just helping, and not experiencing a similar dilema. So all's well that ends well. I am guessing thier problem has been fixed. If anyone else has similar troubles, make sure you are using the most recent version of SU available. Thanks Mike,
