    Holding 2D photo still while changing view
    6 Posts 3 Posters 966 Views 3 Watching
    • C
      Collin Alexander
      I just want to make sure I'm not missing anything here. Am I right that it's impossible to to import a 2D photo as a background, then change the view of the model while keeping the 2D photo unmoved?
      I can import the 2D photo, but it then acts as a face, and moves around in 3D with everything else. I'd like the photo to just hold still while I change the view of the model.
      Possible? I don't want to use photo-match, it doesn't work if the photo's been cropped.
      • soloS
        solo
        You can make it a component and check the face camera option, that way no it will always face you regardless of the view of your model.
        http://www.solos-art.com
        • Wo3DanW
          Wo3Dan
          @collin alexander said:
          ........ import a 2D photo as a background, then change the view of the model while keeping the 2D photo unmoved?........
          Collin,
          goto:
          Window > Styles > Edit > Watermark Settings (=icon4 > (check 'Display watermarks' and click [+sign > import your picture and proceed/follow instructions to adjust settings.]
          cheers,
          Wo3Dan
          • C
            Collin Alexander
            "Always face Camera" didn't work. I selected the photo, then I had to click and drag a rectangle around it to identify it so that "make component" would work. Then I made it a component, and got the "make component" dialog, which included the "always face camera" check box.
            I checked that off, and the photo still orbits, pans etc right along with everything else.
            I can't get "always face camera" to work at all. Does it work for anybody, or is it just me?
            -CA
            • C
              Collin Alexander
              Just saw Wo3Dan's idea, will try that.
              • C
                Collin Alexander
                Yes, Watermark is the way to do it. Thank you very much Wo3Dan.
                Maximum appreciation.
