    64-bit for VISTA version and optimization for Core2 Duo proc
    8 Posts 7 Posters 4.1k Views 7 Watching
    • M
      mylos
      64-bit for VISTA version and optimization for Core2 Duo processor. And better support for
      ATI Radeon 2900XT.
      • AnssiA
        Anssi
        I think that SU works already in all Vista versions, if your drivers are working OK
        I understand that the only advantage of a 64-bit architecture is the possibility to address terabytes of memory, so it is understandable that software houses have no hurry to make 64-bit versions of their products. In everyday computing 64-bit is slower than 32-bit, as there is more for the memory management to waste time upon. What advantage do you see?
        As to ATI, it is the other way round. Ati should make its drivers more OpenGL-compliant.
        Anssi
        • jujuJ
          juju
          Anssi
          Here is a quick intro into the differences between 32 bit and 64 bit computing.
          This is a quick article on 3DS Max 9 that has been recoded for 64 bit use.
          Some more on Max 64 bit. To demonstrate the advantages of 64 bit computing.
          I saw a video a while ago (tried to find the link now, but couldn't just yet) about a direct comparison between 3DS Max 32 bit and 64 bit on the same spec machines and using the same model template. 64 bit computing is sooooo much faster!
          Software houses should indeed step up and get their software recoded for 64 bit usage as more and more medium to high spec personal machines (with the limit of RAM 32 bit can address) are being sold. I'd say give it another year, maybe two then 4GB of RAM will be standard. 4GB of RAM already exceeds the address capability of 32 bit computing.
          I'd also like to see SU scale better to multiple CPU core machines.
          • W
            wahoowetzel
            I really wish Sketchup would produce a 64-bit version. Especially when it comes to using things like vray to render large scenes when the 32-bit RAM cap comes in to play at 1.5~2.0GB...
            Maybe if we ask nicely?
            • soloS
              solo
              This is a screen grab of a model being rendered with Max and Vray, billions of poly's, modelling in SU (3 instances), Internet open with 7 windows yet and my rig was still running smooth.
              http://www.solos-art.com
              • honoluludesktopH
                honoluludesktop
                Solo, Whats ZX Spectrum, and does a i7 have 8 processers?
                • charly2008C
                  charly2008
                  Hi Honoluludesktop,
                  The Sinclair ZX Spectrum 16/48k is a home computer, which in 1982 was tbrought to market from the UK-based Sinclair Research company .
                  I'm always surprised what performance Solo achieved with this part. 😆 😆
                  Karl
                  http://de.wikipedia.org/wiki/Sinclair_ZX_Spectrum
                  • soloS
                    solo
                    I changed it. 😳
