    [Plugin] Explode2Groups
    26 Posts 11 Posters 16.2k Views 11 Watching
    • designerbursaD Offline
      designerbursa
      It's easy to do...
      At the end of the part that make a group out of some entities you add something like -
      compoi = group.to_component
      You can then choose to use methods like compod=compoi.definition; compod.name="Compo#1" to rename the definition as desired.
      But if this relates to the parallel question once you have all exploded entities, still selected, there is a right-click > context-menu native-item "Make Component...", which makes the Selection into a Component rather than into a Group like with "Make Group" - the resultant dialog lets you name the component etc...
      If you already have a Group then the context-menu item "Make Component..." can also make that selected Group into a Component etc...
      This is very hard for amateurs like me πŸ˜„
        The native methods are available to all - with no need for coding skills...
        To simply edit ../Plugins/Explode2groups.rb to finally make components rather than groups...
        Edit that RB file using a plain-text editor [e.g. Notepad++ on PC, or TextWrangler on MAC]
        Find line #43
        all.each{|a| aents.add_group(a) }
        Change it to read
        all.each{|a| **gp=**aents.add_group(a)**;ci=gp.to_component;ci.definition.name="Compo#1"** }
        The default component's name - Compo#1 - increments for each new definition...
        • jujuJ Offline
          juju
          at "designerbursa"
          There are some paid extensions you might want to take a look at as well:
          • nz_ConvertMe
          • nz_EasyGroups
            designerbursa
            Find line #43
            Change it to read
            I tried, it works. But you misunderstood me. I want the components to use the same process. to separate nested components. or is there such a plugin? easy and simple plugin! ..
              If you explode a group [or component-instance] which contains nested groups or component-instances then these are then made separated things. Any geometry is then loose. Explode2Groups takes the loose geometry and regroups it depending on 'connected-ness', the other nested objects are then in the selected group's 'parent' context.
              After using the tool you can use the Outliner to select any of these...
              Another way to achieve your goal would be to use the Outliner, and within it select the nested instances and drag them, still within the Outliner, into another context other than their 'parent' - they will then 'move' into that context...
                designerbursa
                Thank you TIG
                • 2 / 2
