    [Plugin] Explode2Groups
    26 Posts 11 Posters 17.6k Views 11 Watching
      I'm not sue that this plugin does what you want.
      However, I am unclear about what it is you want to do exactly... πŸ˜•
      The way this tool works...
      Select a group, it is exploded, and then any nested geometry within it is made into separate 'connected' groups.
      From your earlier description you seemed to want to take selected groups, and then combine them into a new single group.
      My description explained how to do that by using the native tools...
      Pleas explain step by step what you want to do.
      No video is needed [indeed yours just confused me!]
      Just say what you start with and what you want to have at the end, with any intermediate steps for clarity...
      • designerbursaD Offline
        designerbursa
        Thank you for your interest in TIG.
        I don't know if I got it right, but I haven't.
        I am using Sketchup 2018 version
          designerbursa
          It would be nice if there was a plug-in to create single groups when all nested groups explode.
            But as I said before...
            If you select all of the required groups [and or component-instances] and use Explode from the built-in right-click context-menu item, the result remains selected, so then you can immediately use the built-in right-click context-menu again to Make Group...
            Even if there were a tool to do what you wish you'd need to preselect the groups to process and then run the tool to group them and explode them, so the amount of work you'd have to do is about the same either way.
            So making a script to do this is duplicating what's already available to you ??
              designerbursa
              "expode2component"
              Can you make such a plugin?
                @designerbursa said:
                "expode2component"
                It's easy to do...
                At the end of the part that make a group out of some entities you add something like -
                compoi = group.to_component
                You can then choose to use methods like compod=compoi.definition; compod.name="Compo#1" to rename the definition as desired.
                But if this relates to the parallel question once you have all exploded entities, still selected, there is a right-click > context-menu native-item "Make Component...", which makes the Selection into a Component rather than into a Group like with "Make Group" - the resultant dialog lets you name the component etc...
                If you already have a Group then the context-menu item "Make Component..." can also make that selected Group into a Component etc...
                  designerbursa
                  It's easy to do...
                  This is very hard for amateurs like me πŸ˜„
                    The native methods are available to all - with no need for coding skills...
                    To simply edit ../Plugins/Explode2groups.rb to finally make components rather than groups...
                    Edit that RB file using a plain-text editor [e.g. Notepad++ on PC, or TextWrangler on MAC]
                    Find line #43
                    all.each{|a| aents.add_group(a) }
                    Change it to read
                    all.each{|a| **gp=**aents.add_group(a)**;ci=gp.to_component;ci.definition.name="Compo#1"** }
                    The default component's name - Compo#1 - increments for each new definition...
                    • jujuJ Offline
                      juju
                      at "designerbursa"
                      There are some paid extensions you might want to take a look at as well:
                      • nz_ConvertMe
                      • nz_EasyGroups
                        designerbursa
                        Find line #43
                        Change it to read
                        I tried, it works. But you misunderstood me. I want the components to use the same process. to separate nested components. or is there such a plugin? easy and simple plugin! ..
                          If you explode a group [or component-instance] which contains nested groups or component-instances then these are then made separated things. Any geometry is then loose. Explode2Groups takes the loose geometry and regroups it depending on 'connected-ness', the other nested objects are then in the selected group's 'parent' context.
                          After using the tool you can use the Outliner to select any of these...
                          Another way to achieve your goal would be to use the Outliner, and within it select the nested instances and drag them, still within the Outliner, into another context other than their 'parent' - they will then 'move' into that context...
                            designerbursa
                            Thank you TIG
                            • 2 / 2
