    [Plugin] Explode2Groups
    26 Posts 11 Posters 16.6k Views 11 Watching
    • TIGT Online
      This script adds a context-menu if the 1st in a selection is a group - 'Explode to Groups'. All connected geometry within that group is grouped into separate sub-groups and the original group exploded...
      Get the latest version from the here...
      https://sketchucation.com/pluginstore?pln=Explode2Groups
        matt77
        Excellent script
        many thanks
        only just come across it..
        all the best
        matt
        • RayOchoaR Offline
          RayOchoa
          what do you mean by this?
          CaR DeSiGnS bY mE
          http://ray-ochoa.com
          • cerevellumC Offline
            cerevellum
            Hmm, I think this could come in handy on this model I'm currently working on. Checked it out at home and will probably DL it again tomorrow! Thanks!
              Mr S
              Looks like another handy tool to have.
              Thanks.
              Mr S
              • bagateloB Offline
                bagatelo
                Does exist some plugin that just transforms components in groups and groups in components?
                • Chris FullmerC Offline
                  Nope. What would need such a thing for?
                  All my Plugins I've written
                  • bagateloB Offline
                    bagatelo
                    Because at this time, I'm importing things from 3dsMAX to Sketchup, and all subobjects are components, always. I don't like that, I like groups for subobjects, because it doesn't pollute the components browser.
                    • pbacotP Offline
                      To place multiple components then turn each instance into a group for different modifications, without having to select each one and explode, then group, separately? Still this tool can be used to help in that case.
                      • Y Offline
                        yvani
                        does this plugin work with SU 2017? I don't succeed ....
                        • TIGT Online
                          This tool does not work in v2017.
                          Trimble changed the way SketchUp keeps references to entities during exploding etc, so this tool now fails.
                          Sorry, but it is 10 years old. 😞
                          Search for other similar tools which might have been update-able...
                          • TIGT Online
                            You are in luck !
                            I checked the code and it was a relatively simple fix to make it v2017 compatible !
                            Here's v2.0
                            • designerbursaD Offline
                              designerbursa
                              Hi TIG
                              Thanks this plugin! ..
                              Selecting each group one by one detonates. Can the whole group or components make a single selection?
                              I want all drawings in the file to be a single group or component when I run the plug-in
                              • TIGT Online
                                Why not just Explode everything that's selected [right-click context-menu], the results stay selected, now use context-menu Make Group or Make Component ?
                                • TIGT Online
                                  I'm not sue that this plugin does what you want.
                                  However, I am unclear about what it is you want to do exactly... 😕
                                  The way this tool works...
                                  Select a group, it is exploded, and then any nested geometry within it is made into separate 'connected' groups.
                                  From your earlier description you seemed to want to take selected groups, and then combine them into a new single group.
                                  My description explained how to do that by using the native tools...
                                  Pleas explain step by step what you want to do.
                                  No video is needed [indeed yours just confused me!]
                                  Just say what you start with and what you want to have at the end, with any intermediate steps for clarity...
                                    designerbursa
                                    Thank you for your interest in TIG.
                                    I don't know if I got it right, but I haven't.
                                    I am using Sketchup 2018 version
                                      designerbursa
                                      It would be nice if there was a plug-in to create single groups when all nested groups explode.
                                      • TIGT Online
                                        But as I said before...
                                        If you select all of the required groups [and or component-instances] and use Explode from the built-in right-click context-menu item, the result remains selected, so then you can immediately use the built-in right-click context-menu again to Make Group...
                                        Even if there were a tool to do what you wish you'd need to preselect the groups to process and then run the tool to group them and explode them, so the amount of work you'd have to do is about the same either way.
                                        So making a script to do this is duplicating what's already available to you ??
                                          designerbursa
                                          "expode2component"
                                          Can you make such a plugin?
                                          • TIGT Online
                                            @designerbursa said:
                                            "expode2component"
                                            It's easy to do...
                                            At the end of the part that make a group out of some entities you add something like -
                                            compoi = group.to_component
                                            You can then choose to use methods like compod=compoi.definition; compod.name="Compo#1" to rename the definition as desired.
                                            But if this relates to the parallel question once you have all exploded entities, still selected, there is a right-click > context-menu native-item "Make Component...", which makes the Selection into a Component rather than into a Group like with "Make Group" - the resultant dialog lets you name the component etc...
                                            If you already have a Group then the context-menu item "Make Component..." can also make that selected Group into a Component etc...
                                            • 1 / 2
