    [Plugin] Explode2Groups
    26 Posts 11 Posters 16.7k Views 11 Watching
      Mr S
      Looks like another handy tool to have.
      Thanks.
      Mr S
      • bagateloB Offline
        bagatelo
        Does exist some plugin that just transforms components in groups and groups in components?
        • Chris FullmerC Offline
          Nope. What would need such a thing for?
          • bagateloB Offline
            bagatelo
            Because at this time, I'm importing things from 3dsMAX to Sketchup, and all subobjects are components, always. I don't like that, I like groups for subobjects, because it doesn't pollute the components browser.
            • pbacotP Offline
              To place multiple components then turn each instance into a group for different modifications, without having to select each one and explode, then group, separately? Still this tool can be used to help in that case.
              • Y Offline
                yvani
                does this plugin work with SU 2017? I don't succeed ....
                  This tool does not work in v2017.
                  Trimble changed the way SketchUp keeps references to entities during exploding etc, so this tool now fails.
                  Sorry, but it is 10 years old. 😞
                  Search for other similar tools which might have been update-able...
                    You are in luck !
                    I checked the code and it was a relatively simple fix to make it v2017 compatible !
                    Here's v2.0
                    https://sketchucation.com/pluginstore?pln=Explode2Groups
                    • designerbursaD Offline
                      designerbursa
                      Hi TIG
                      Thanks this plugin! ..
                      Selecting each group one by one detonates. Can the whole group or components make a single selection?
                      I want all drawings in the file to be a single group or component when I run the plug-in
                        Why not just Explode everything that's selected [right-click context-menu], the results stay selected, now use context-menu Make Group or Make Component ?
                          I'm not sue that this plugin does what you want.
                          However, I am unclear about what it is you want to do exactly... 😕
                          The way this tool works...
                          Select a group, it is exploded, and then any nested geometry within it is made into separate 'connected' groups.
                          From your earlier description you seemed to want to take selected groups, and then combine them into a new single group.
                          My description explained how to do that by using the native tools...
                          Pleas explain step by step what you want to do.
                          No video is needed [indeed yours just confused me!]
                          Just say what you start with and what you want to have at the end, with any intermediate steps for clarity...
                            designerbursa
                            Thank you for your interest in TIG.
                            I don't know if I got it right, but I haven't.
                            I am using Sketchup 2018 version
                              designerbursa
                              It would be nice if there was a plug-in to create single groups when all nested groups explode.
                                But as I said before...
                                If you select all of the required groups [and or component-instances] and use Explode from the built-in right-click context-menu item, the result remains selected, so then you can immediately use the built-in right-click context-menu again to Make Group...
                                Even if there were a tool to do what you wish you'd need to preselect the groups to process and then run the tool to group them and explode them, so the amount of work you'd have to do is about the same either way.
                                So making a script to do this is duplicating what's already available to you ??
                                  designerbursa
                                  "expode2component"
                                  Can you make such a plugin?
                                    @designerbursa said:
                                    "expode2component"
                                    It's easy to do...
                                    At the end of the part that make a group out of some entities you add something like -
                                    compoi = group.to_component
                                    You can then choose to use methods like compod=compoi.definition; compod.name="Compo#1" to rename the definition as desired.
                                    But if this relates to the parallel question once you have all exploded entities, still selected, there is a right-click > context-menu native-item "Make Component...", which makes the Selection into a Component rather than into a Group like with "Make Group" - the resultant dialog lets you name the component etc...
                                    If you already have a Group then the context-menu item "Make Component..." can also make that selected Group into a Component etc...
                                      designerbursa
                                      It's easy to do...
                                      This is very hard for amateurs like me 😄
                                        The native methods are available to all - with no need for coding skills...
                                        To simply edit ../Plugins/Explode2groups.rb to finally make components rather than groups...
                                        Edit that RB file using a plain-text editor [e.g. Notepad++ on PC, or TextWrangler on MAC]
                                        Find line #43
                                        all.each{|a| aents.add_group(a) }
                                        Change it to read
                                        all.each{|a| **gp=**aents.add_group(a)**;ci=gp.to_component;ci.definition.name="Compo#1"** }
                                        The default component's name - Compo#1 - increments for each new definition...
                                        • jujuJ Offline
                                          juju
                                          at "designerbursa"
                                          There are some paid extensions you might want to take a look at as well:
                                          • nz_ConvertMe
                                          • nz_EasyGroups
                                            designerbursa
                                            Find line #43
                                            Change it to read
                                            I tried, it works. But you misunderstood me. I want the components to use the same process. to separate nested components. or is there such a plugin? easy and simple plugin! ..
