    Length woes
    11 Posts 6 Posters 1.7k Views 6 Watching
    • Al HartA Offline
      Al Hart
      Here is an interesting "feature" of the SketchUp Length class:
      l1 = 0.00.to_l # create a 0 Length
      l2 = 0.000001.to_l
      l1 == l2 # returns true
      although they are reported as equal, they print as different values.
      This showed up when trying to determine when a normal vector was 0
      v1 = Geom::Vector3d.new(0,0,0)
      v1.length < 0.00001 # returns false
      Al Hart
      IRender nXt from Render Plus
      • G Offline
        g2ktcf
        Al,
        I do remember reading something about "within a tolerance" for many of the SU functions. I do not know what the tolerance is but you may be getting two values the the sytem considers EQUAL within a tolerance. Then the "<" would be false as both numbers are Zero within this established tolerance (i thought it was 0.01")
        just my quick after lunch thoughts...
        Chris
        • Didier BurD Offline
          Didier Bur
          Yes,
          In fact, I often had to write my own "within tolerance" method, as well as several other coders I think. Safer... 😉
          DB
          • G Offline
            g2ktcf
            What is the actual "tolerance" value? Anyone?
              todd burch
              Try Float::EPSILON.
              Todd
              • G Offline
                g2ktcf
                Okay...that's a REALLY small number. 😕
                • G Offline
                  g2ktcf
                  Okay, I had to play this morning on this.
                  I took the same L1 and L2 example and varied the value of l2 by a factor of 10 until the L1==L2 statement returned FALSE. It seems that a value of l2=0.001 is the point at which things change. I tried an l2 = 0.0005 and that returned TRUE. This must be handled in the class methods....Right???
                  • G Offline
                    g2ktcf
                    It seems the same argument goes for the Zero Vector. Setting either of these with a value less than 0.001" will result in SU "seeing' them as zero even though they print out differently. 😮
                      "float-tolerance.rb" is by RickW [I think - I hope he doesn't mind me repeating it in its entirety here]
                      class Float
                      	def =~(num2,tol=10000)
                      		num1=(self*tol).to_i
                      		num2=(num2*tol).to_i
                      		return true if num1==num2
                      		return nil
                      end #class Float
                      Then you test two floats thus:
                      float1 =~ float2
                      It returns false or true
                      You could adjust the float tol part to suit...
                        RickW
                        I don't mind as long as there's a link 😄
                        (http://www.smustard.com/script/FloatTolerance)
                        RickW
                        [www.smustard.com](http://www.smustard.com)
                        • G Offline
                          g2ktcf
                          I actually found this implied in an example in the length class API. If you use a float, the math comes out like you would expect. The Length class is where this changes (as Al suspected). Notice that the 0.001" value that I got while testing is not mentioned as a limiting factor.
                          The < method is used to see if one length is less than another length.
                          Syntax
                          status = length1 < length2
                          Arguments
                          length1 - a length value
                          length2 - a length value
                          Return Value
                          status - true if length1 is < length2; false if length1 is not < length2
                          Comments
                          For example, if l1 = 1.0.inch and l2 = 1.000001.inch then l1 == l2 so l1 < l2 should return false.
