    New script: Munsell colors maker
    5 Posts 4 Posters 2.2k Views 4 Watching
    • Didier BurD
      Didier Bur
      The Munsell Maker is ready for download here:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1526
      You can cretate SU materials (colors) based on the Munsell naming convention, build colors libraries, and more.
      Regards,
      DB
      • TIGT
        Didier
        Thanks for the new script... unfortunately it doesn't work straight away - IF the user's current directory isn't the Plugins folder !
        You need to add some code to each def's file reading part like this:
          file=File.dirname(Sketchup.find_support_file("Munsell.rb","Plugins/"))+"/"
          in_file=File.open(file+"Munsell_hexa.txt","r")
        This then makes the thing work as intended...
        You could also add a 'help' menu item like:
        def munsell_help
          help="file;///"+Sketchup.find_support_file("Munsell Maker User Guide.pdf","Plugins/")
          UI.messagebox("***ERROR***\n\n.../Plugins/Munsell Maker User Guide.pdf\n\nNOT found.") if not UI.openURL(help)
        end#def help
            main_menu.add_separator
            main_menu.add_item("Help..."){munsell_help}
        • Didier BurD
          Didier Bur
          Coooool,
          Many thanx TIG.
          πŸ˜„
          UPDATED 09.13.07. Same download link.
          DB
          • D
            digby dart
            Thank you Didier. πŸ˜„
            I must at least one of your scripts daily. Clearly you have increased the value of Sketchup enormously. Your generosity is much appreciated.
            [digby dart]
              Bug fixed indeed! That's cool Didier. Thank you.
