    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Roof.rb v1
    80 Posts 20 Posters 11.7k Views 20 Watching
      rhankc
      Thanks for the detailed explanation.
      I get pyramid roof no problem. I havent tried a mansard, but I will.
      The only way I can get gable to respond is using a ^ before a specified height. The other techniques dont produce anything. I was seeing the difference in what was entered for eaves etc. and thought it was a SU thing so I had changed my units to decimal-inches and was still getting the ft-in after entering a value in inches. That is why I mentioned it. it is now entering as expected.
      After a few roof sessions, (keep making different roof modules) I get the image I posted earlier even though I have the edge and horizontal surface selected. It wont get over the message until I start a new file.
      This is going to be a great tool. thanks
      Hank
      • TIGT Online
        @rhankc said:
        The only way I can get gable to respond is using a ^ before a specified height. The other techniques dont produce anything...
        IF you open a new model, open the Ruby Console and then make a rectangle + push'pulled to a volume, then run Roof...Gable and accept all of the defaults that appear in the dialog what happens ?
        With your 'non-rectangle' error... it's as if multiple editing make what is a rectangle slightly skewed. Maybe I need to build in some 'tolerance' as to what makes a 'rectangle'...
          rhankc
          that is the perfect question...
          the first run after the initial boot, I built a rectangular cube, and ran the roof tool on gable after selecting one edge and the top plane. I saw nothing happen.
          I did it again exactly as you described for a gable: nothing happened.
          To get a roof model the first attempt, this is what I tried: I went thru the menu and toggled each setting, basically rekeyed everything there and entered 12:12 for a pitch. I got nothing; then I noticed the ^ wasn't included in the pitch indicator, so I set ^12 , and got a low pitch roof.
          here is the ruby console script:
          Added: 1 :: #Sketchup::Face:0x4e3ad38
          Cleared: #Sketchup::Selection:0x4e58480
          Added: 1 :: #Sketchup::Face:0x4e3a0c0
          BulkChange: 1
          BulkChange: 2
          Error: #<NoMethodError: undefined method to_f' for ["1", "2"]:Array> (eval):1385:in dialog_gable'
          (eval):1494:in gable' (eval):2722 (eval):2722:in call'
          Hank
          • H Offline
            humanticnc
            hi halli
            http://www.sketchucation.com/forums/scf/sas/Ruby/roof-1.png
              dylan
              Just tried this on Vista also with SU Pro latest version and still does not work.
              http://dmdarchitecture.co.uk/
                rhankc
                Dylan,
                There is definatly some technique to it, but when there is a roof drawn it is a pretty thing! I think there is alot of computing power going into this thing. Try a gable, Use the ^ (carat) or whatever it is,enter a # rekey all the menu settings, should give a roof.
                Hank
                • TIGT Online
                  This is a real mystery... but it shall be solved.
                  If you open a new model, open the Ruby Console, make a rectangle, pushpull it into a box, select the top face and an edge belonging to that face (with Shift or Ctrl) and run the tool Roof...Gable..., then accept all of the dialog's defaults with an OK what happens ? Any error or console messages, is there a group made where the roof might be, etc.
                  I appreciate that its not working is frustrating for you, BUT it's doubly frustrating for me when it seems to works in identical set-ups elsewhere without any hitch, and you're not giving me many clues as to what's wrong - except that, "it's not working..."
                  I appreciate your feedback, but please can it be a bit more detailed...
                    rhankc
                    wish I had three monitors for this:
                    New untitled.There is a template here
                    Here is the first step:Ruby console on:Rectangle push/pull into cube:
                    console text:
                    Added: 1 :: #Sketchup::Face:0x4415260
                    Cleared: #Sketchup::Selection:0x4438480
                    Added: 1 :: #Sketchup::Face:0x44148e8
                    Select edge and plane:
                    BulkChange: 1
                    BulkChange: 2
                    Plugins>Roof>got the message I attached earlier. Going to start over.
                    new untitled, and all the way to the flyout at gable selection was the same except this time I got the Gable roof setting menu.
                    Accept all defaults>OK
                    The box plane & line is still hi-lited and absolutely nothing happened, no flash or resemblence of a roof.
                    Here is the last sequence of commands ruby console text:
                    I am going to load another start template, if it works any better I'll let you know.
                    Hank
                      rhankc
                      Ok, I fired up my laptop which has XP 2002 SP2 and a ATI Mobility Radeon X600 G.C. that has a version of 5 & 6 on it but no rubies to speak of:examples.rb,RPS_Ray Trace.Rb, Utilities.rb,parametric.rb,oniondome.rb,bezier.rb,grid.rb,windows.rb,shapes.rb, rectangle .rb, and the roof.rb
                      There are very few inhibitors here, and I could possibly uninstall all but the defaults if you think they may be in the way.
                      I had the same response as the previous attempt, which is no group, stuff still highlited etc. on both versions.
                      Hank
                        seasdes
                        Thanks TIG. A truly remarkable script. You have put a lot of thought into this script as always.It also works fine in SU6 and XP Pro.
                        Seasdes
                        Using Sketchup Pro 2019
                          alpro
                          TIG, this is a great looking script, unfornuately it also isn't working for me, I select a face, get the first dialog box, hit ok and get nothing, no errors, no roof, no second dialog box. I'm running Vista and SU Pro 6.0.515, hope you can get it figured out because like I said, it looks like a great script.
                          Mike
                            alpro
                            TIG, here's a screen shot of my ruby console.
                            Mike
                            http://www.sketchucation.com/forums/scf/sas/Ruby/errors.jpg
                              dylan
                              Hi TIG,
                              I have tried the script as you asked and have posted the results.
                              I tried Gable Ended Roof and Hipped Roof.
                              Gable ended I picked the top face and one edge and got the attached error (image 1 & 2).
                              Hipped roof I get the following info in the ruby box (image 3)
                              Running on XP SP2, SU Pro 6.0.515
                              http://www.sketchucation.com/forums/scf/sas/Ruby/3.jpg
                              http://www.sketchucation.com/forums/scf/sas/Ruby/2.jpg
                              http://www.sketchucation.com/forums/scf/sas/Ruby/1.jpg
                              • TIGT Online
                                Mike
                                I've posted v1.1 that fixes your problem = http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1516
                                Replace the current version with this one.
                                At least that error report is fixed. Now for some other errors...
                                • TIGT Online
                                  ...I have tried the script as you asked and have posted the results.
                                  Hipped roof I get the following info in the ruby box...
                                  The previous post links to an updated version v1.1 that fixes the A:B glitch. The Gable and Pyramid tools only let you work on a horizontal rectangle. Sometimes what appears to be a rectangle isn't (as far as Ruby is concerned) I'm trying to come up with a 'tolerance' method...
                                    alpro
                                    TIG, I'm still getting the same errors, after replacing the current version. Thanks for the quick reply to last post though. Hope you get it figured out, let me know if you need any additional info in reguards to my computer specs. Thanks.
                                    Mike
                                    http://www.sketchucation.com/forums/scf/sas/Ruby/errors2.jpg
                                      alpro
                                      Sorry, must of did something wrong the first time, can produce a hip roof now but when I try anything else I get the following. Thanks again, this definitely can be a very useful script.
                                      Mike
                                      http://www.sketchucation.com/forums/scf/sas/Ruby/errors3.jpg
                                        dylan
                                        Thanks TIG, the new script now works perfectly - What a great Ruby!
                                        • TIGT Online
                                          @alpro said:
                                          TIG, I'm still getting the same errors, after replacing the current version. Thanks for the quick reply to last post though. Hope you get it figured out, let me know if you need any additional info in regards to my computer specs. Thanks.
                                          Mike
                                          Are you sure you overwrote v1.0 with v1.1 ?
                                          No matter... put this attached file into you Plugins folder. It should fix the problem either way...
                                          301 Moved Permanently
                                          (www.sketchucation.com)
                                            rhankc
                                            Tig, just ran a couple gable roofs with the new spin. It worked with the default setup, with pitch entered, I played with the eaves a bit, think she is looking good..
                                            I want to congratulate you...humbly...this is like a grand slam. I am really looking forward to putting this roof tool through it's paces. Thanks
                                            Hank
                                            • 2 / 4
