    Roof.rb v1
    80 Posts 20 Posters 16.8k Views 20 Watching
      rhankc
      wish I had three monitors for this:
      New untitled.There is a template here
      Here is the first step:Ruby console on:Rectangle push/pull into cube:
      console text:
      Added: 1 :: #Sketchup::Face:0x4415260
      Cleared: #Sketchup::Selection:0x4438480
      Added: 1 :: #Sketchup::Face:0x44148e8
      Select edge and plane:
      BulkChange: 1
      BulkChange: 2
      Plugins>Roof>got the message I attached earlier. Going to start over.
      new untitled, and all the way to the flyout at gable selection was the same except this time I got the Gable roof setting menu.
      Accept all defaults>OK
      The box plane & line is still hi-lited and absolutely nothing happened, no flash or resemblence of a roof.
      Here is the last sequence of commands ruby console text:
      Error: #<NoMethodError: undefined method to_f' for ["1", "2"]:Array> (eval):1385:in dialog_gable'
      (eval):1494:in gable' (eval):2722 (eval):2722:in call'
      I am going to load another start template, if it works any better I'll let you know.
      Hank
        rhankc
        Ok, I fired up my laptop which has XP 2002 SP2 and a ATI Mobility Radeon X600 G.C. that has a version of 5 & 6 on it but no rubies to speak of:examples.rb,RPS_Ray Trace.Rb, Utilities.rb,parametric.rb,oniondome.rb,bezier.rb,grid.rb,windows.rb,shapes.rb, rectangle .rb, and the roof.rb
        There are very few inhibitors here, and I could possibly uninstall all but the defaults if you think they may be in the way.
        I had the same response as the previous attempt, which is no group, stuff still highlited etc. on both versions.
        Hank
          seasdes
          Thanks TIG. A truly remarkable script. You have put a lot of thought into this script as always.It also works fine in SU6 and XP Pro.
          Seasdes
          Using Sketchup Pro 2019
            alpro
            TIG, this is a great looking script, unfornuately it also isn't working for me, I select a face, get the first dialog box, hit ok and get nothing, no errors, no roof, no second dialog box. I'm running Vista and SU Pro 6.0.515, hope you can get it figured out because like I said, it looks like a great script.
            Mike
              alpro
              TIG, here's a screen shot of my ruby console.
              Mike
              http://www.sketchucation.com/forums/scf/sas/Ruby/errors.jpg
                dylan
                Hi TIG,
                I have tried the script as you asked and have posted the results.
                I tried Gable Ended Roof and Hipped Roof.
                Gable ended I picked the top face and one edge and got the attached error (image 1 & 2).
                Hipped roof I get the following info in the ruby box (image 3)
                Running on XP SP2, SU Pro 6.0.515
                http://www.sketchucation.com/forums/scf/sas/Ruby/3.jpg
                http://www.sketchucation.com/forums/scf/sas/Ruby/2.jpg
                http://www.sketchucation.com/forums/scf/sas/Ruby/1.jpg
                http://dmdarchitecture.co.uk/
                  Mike
                  I've posted v1.1 that fixes your problem = http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1516
                  Replace the current version with this one.
                  At least that error report is fixed. Now for some other errors...
                    ...I have tried the script as you asked and have posted the results.
                    Hipped roof I get the following info in the ruby box...
                    The previous post links to an updated version v1.1 that fixes the A:B glitch. The Gable and Pyramid tools only let you work on a horizontal rectangle. Sometimes what appears to be a rectangle isn't (as far as Ruby is concerned) I'm trying to come up with a 'tolerance' method...
                      alpro
                      TIG, I'm still getting the same errors, after replacing the current version. Thanks for the quick reply to last post though. Hope you get it figured out, let me know if you need any additional info in reguards to my computer specs. Thanks.
                      Mike
                      http://www.sketchucation.com/forums/scf/sas/Ruby/errors2.jpg
                        alpro
                        Sorry, must of did something wrong the first time, can produce a hip roof now but when I try anything else I get the following. Thanks again, this definitely can be a very useful script.
                        Mike
                        http://www.sketchucation.com/forums/scf/sas/Ruby/errors3.jpg
                          dylan
                          Thanks TIG, the new script now works perfectly - What a great Ruby!
                            @alpro said:
                            TIG, I'm still getting the same errors, after replacing the current version. Thanks for the quick reply to last post though. Hope you get it figured out, let me know if you need any additional info in regards to my computer specs. Thanks.
                            Mike
                            Are you sure you overwrote v1.0 with v1.1 ?
                            No matter... put this attached file into you Plugins folder. It should fix the problem either way...
                            404 Not Found
                            (www.sketchucation.com)
                              rhankc
                              Tig, just ran a couple gable roofs with the new spin. It worked with the default setup, with pitch entered, I played with the eaves a bit, think she is looking good..
                              I want to congratulate you...humbly...this is like a grand slam. I am really looking forward to putting this roof tool through it's paces. Thanks
                              Hank
                                davekn
                                Hi Tig
                                First off - many thanks for the script it looks great.
                                However at the moment I don't appear to be able get it to do anything at all.
                                I am using an iMAC & Sketchup Pro and when I select a horizontal face on the top of a box & go to the plugins folder & pick roof - hipped roof then nothing happens at all - I don't even get the first dialogue box.
                                If I select a face & gable edge & pick Gable ended roof then I get the message
                                'You must select one horizontal RECTANGULAR [= right-angled] face, and one edge (that's at the 'gable') !' even though this is what I have done. I have tried just about every combination of edges & faces to no avail.
                                If you need any further info then let me know.
                                Regards Dave
                                  davekn
                                  Have you downloaded v1-1 that fixes some errors ?
                                  404 Not Found
                                  This should get you somewhere. However, the accuracy of the 'rectangle' checking is perhaps causing some problems and I'm looking at ways of building in some 'tolerance'. Have you simply drawn a rectangle 'on the floor' and tried that ?
                                    davekn
                                    Hi Tig
                                    Yes I downloaded v1 & I have tried drawing a rectangle on the floor but with exactly the same results.
                                    I had to rename the the V1 download as I have the problem that all downloads apart from zipped files come in as 'download.php'. The original was okay as it came in a zipped file.
                                    I presume the v1 file is still named roof.rb
                                    many thanks Dave
                                      @davekn said:
                                      Hi Tig
                                      many thanks Dave
                                      Try the v1.1 zip to be sure...
                                        davekn
                                        Hi Tig
                                        Sorry - I have just tried that as well.
                                        Same result.
                                        Dave
                                        • boofredlayB Offline
                                          boofredlay
                                          TIG, version 1.1 only worked on the Hipped and Mansard, not on the Gable or Pyramid. I went to church, went for a walk, tried it again and it works... hmmm.
                                          Anyway, for now all 4 roofs work. Thanks a bunch. I can see me using this one quite a bit.
                                            alpro
                                            TIG, I can get all four roofs to work some of the time, pretty much hit or miss,even tried a rectangle on the floor as you suggested to davekn, it seems to work better when I try to put a roof over a square instead of a rectangle, works pretty much all of the time, so I'm guessing that you are correct in thinking of some rectangle tolerance method. Still a great script though, thanks.
                                            Mike
                                            • 2 / 4
