    Purge
    13 Posts 5 Posters 3.1k Views 5 Watching
    • boofredlayB
      boofredlay
      I know there is a purge all unused ruby:
      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_edi_page.htm
      I was wondering if there was a ruby for purging all layers, colors, components, etc... that are being used.
      If not, could it be written? Purge everything to default colors and 0 layer etc...
      • TIGT
        This has been around for a while (v6 only)...
        PurgeAll.rb
        • boofredlayB
          boofredlay
          TIG, that is the same one I posted a link to. I just replaced the one I had with the one you posted above and it did the exact same thing, purged anything that is being unused.
          This I knew about, what I am asking about is a script that will purge colors or layers etc... that are being used. I.E. delete the colors from a model and leave only the default.
          • T
            todd burch
            There is a RemoveMaterials at http://www.smustard.com/script/RemoveMaterials that will remove all materials in use in the model. I suspect there is a collapse everything to layer0 script around somewhere too - maybe on Didier's site. I don't remember seeing a script for removing all styles though. I wrote a PurgeManager back during the V6 beta, but never released it. It uses WebDialogs, has buttons, gives you a before and after image of the counts (before and after purge), and is generally pretty neat. But, I then went on to add the File Size specification, and ran into cross platform issues that turned into bug reports and feature requests, and there it sits - never released.
            Todd
            • T
              tomsdesk
              Boo, what am I missing (again :`) I use the "purge unused" in the statistics section of the model info menu...?
              2.5D Trees & Shrubs!
              • boofredlayB
                boofredlay
                Thanks Todd, that is what I was searching for. I will try to find the collapse to layer 0 you mentioned.
                Tom, I was looking for a Purge Used script, not Unused πŸ˜‰
                And the PurgeAll script that TIG attached will purge all unused components, layers, materials, and styles then generate a report. I guess the only difference between the purge unused in the statisitcs and the script is the generated report, correct me guys if I am wrong.
                • T
                  tomsdesk
                  Oops...in the wrong forum for skimming, sorry.
                  • M
                    miikka1978
                    Is there something similar to RemoveMaterials, which would also delete the materials from the paint bucket (in model- pull down menu)?
                    • TIGT
                      My Purge All script lets you choose NOT to purge some types e.g. Layers can be left alone whilst everything else is cleaned up...
                      • TIGT
                        My Purge All could be used (cannibalised) to purge unused materials after they are no longer used when RemoveMaterials has been run...
                        • TIGT
                          This is a 'Default All Layers' (in selection) script that I've just cobbled together. Please try and report back...
                          default_all_layers.rb
                          • boofredlayB
                            boofredlay
                            TIG, that is great. Works like a charm. Just run it, then run purgeall and poof.
                            Thanks.
                            • TIGT
                              Thanks.
                              At least that works ! Now for Roof.rb glitches. Perhaps you should all go to church and retry it ?
