    Purge
    13 Posts 5 Posters 3.0k Views 5 Watching
    • boofredlayB Offline
      boofredlay
      I know there is a purge all unused ruby:
      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_edi_page.htm
      I was wondering if there was a ruby for purging all layers, colors, components, etc... that are being used.
      If not, could it be written? Purge everything to default colors and 0 layer etc...
        This has been around for a while (v6 only)...
        PurgeAll.rb
          boofredlay
          TIG, that is the same one I posted a link to. I just replaced the one I had with the one you posted above and it did the exact same thing, purged anything that is being unused.
          This I knew about, what I am asking about is a script that will purge colors or layers etc... that are being used. I.E. delete the colors from a model and leave only the default.
            todd burch
            There is a RemoveMaterials at http://www.smustard.com/script/RemoveMaterials that will remove all materials in use in the model. I suspect there is a collapse everything to layer0 script around somewhere too - maybe on Didier's site. I don't remember seeing a script for removing all styles though. I wrote a PurgeManager back during the V6 beta, but never released it. It uses WebDialogs, has buttons, gives you a before and after image of the counts (before and after purge), and is generally pretty neat. But, I then went on to add the File Size specification, and ran into cross platform issues that turned into bug reports and feature requests, and there it sits - never released.
            Todd
              tomsdesk
              Boo, what am I missing (again :`) I use the "purge unused" in the statistics section of the model info menu...?
              2.5D Trees & Shrubs!
                boofredlay
                Thanks Todd, that is what I was searching for. I will try to find the collapse to layer 0 you mentioned.
                Tom, I was looking for a Purge Used script, not Unused πŸ˜‰
                And the PurgeAll script that TIG attached will purge all unused components, layers, materials, and styles then generate a report. I guess the only difference between the purge unused in the statisitcs and the script is the generated report, correct me guys if I am wrong.
                  tomsdesk
                  Oops...in the wrong forum for skimming, sorry.
                    miikka1978
                    Is there something similar to RemoveMaterials, which would also delete the materials from the paint bucket (in model- pull down menu)?
                      My Purge All script lets you choose NOT to purge some types e.g. Layers can be left alone whilst everything else is cleaned up...
                        My Purge All could be used (cannibalised) to purge unused materials after they are no longer used when RemoveMaterials has been run...
                          This is a 'Default All Layers' (in selection) script that I've just cobbled together. Please try and report back...
                          default_all_layers.rb
                            boofredlay
                            TIG, that is great. Works like a charm. Just run it, then run purgeall and poof.
                            Thanks.
                              Thanks.
                              At least that works ! Now for Roof.rb glitches. Perhaps you should all go to church and retry it ?
