    [Plugin] Area Formatting
    3 Posts 2 Posters 11.7k Views 2 Watching
      This lets you format area text tags with any desired area format... For example you are working in mm but want areas in m2...
      [flash=800,600:268zxfdc]http://www.youtube.com/v/Txue6Jo0DZA[/flash:268zxfdc]
      Before picking the tool off the Plugins|Extensions menu select what you want formatting or let it choose from 'everything' available...
      It converts mm2, cm2, m2, in2 and ft2 into mm2, cm2, m2, hectares, sq in, sq ft, sq yds and acres; all as you might select from the dialog...http://sketchucation.com/resources/pluginstore?pln=AreaFormat
      • gullfoG Offline
        gullfo
        wonder if its one of those unicode things where you have to have the regex search for the specific character that looks like its superscript... U+00B2
        Glenn
        http://www.runnel.com
          Here's v2.0 http://sketchucation.com/pluginstore?pln=AreaFormat
          It has been updated to also work with the newer SketchUp versions area-reporting format - mm² OR Millimeter ² etc.
          It also offers two new alternatives for inch/feet area formats - in² or sqin, and ft² or sqft...
