    Scaling
    3 Posts 3 Posters 639 Views 3 Watching
    • P Offline
      perk
      Is there a difference between scaling and stretching? For intance, if I bring in a door or window and scale it to the size I want the frame or mullions change as well. Another words I would like to keep the frame 2" thick while increasing the height of the door by 3-5/16" but when I scale it the frame increases in size propotionaly as well.
      Jeff
      • boofredlayB Offline
        boofredlay
        Yes there is a difference. You will have to edit the component, select the one side of the frame and move/stretch it to the desired width. Same with the height.
        • G Offline
          Gidon Yuval
          Hi Perk,
          There is a very easy way to modify the dimmensions of a component or group without distorting it's parts. I went into this in answer to another question and posted some pictures by way of explanation. You can find it here:
          http://www.sketchucation.com/forums/scf/viewtopic.php?p=4248#p4248
          The explanation and pictures start just after the picture of the hamster with the gun. Seriously, there's a picture of a hamster with a gun.
          If you don't know where you're going, you're never going to get there.
