    ATI Mobility Radeon HD 2600
    13 Posts 11 Posters 4.4k Views 11 Watching
    • A
      Asher77
      I am posting in the hope that someone somewhere out there may be able to shed some light on my problem.
      I have a Brand new Toshiba Satelite Pro P200 with the following specs.
      Intel Core 2 Duo T7300 (2.0ghz)
      3 Gbs of Ram (2gb 1gb config)
      ATI Mobility Radeon HD 2600 (256mb dedicated memory with 512mb share)
      200GB Sata Hard Drive. DVD burner etc etc.
      The Laptop is running Windows XP SP2 fully updated.
      The ATI Card has full support for OpenGL 2.0 (SU needs 1.5)
      Everything works sweet except when working and spinning models in sketchup the program reacts very slowly and depending on the site of the model can take up to 30 seconds to respond. I am running the most current drivers off the Toshiba Website. I have tried 3rd Party drivers and even modified the AMD ATI desktop drivers to run on the laptop with no change or noticeable improvement to sketch up performace.
      Has anyone had a similar problem. I usually use nVidia Graphics Cards but due to the need for Windows XP on our network, 17 inch monitor required it left me with a laptop with an ATI Graphics card. Can this be fixed, do i rip out the ATI gcard and put in an nVidia?
      • A
        Asher77
        Under XP SP2 the ATI Control Centre was reporting that there was 512mb of available memory to the graphics card.
        I have since restored Vista to the laptop in a last ditch attempt to see if it will work better for what ever reason, sheer luck, etc. The graphics card now reports to having 1536mbs of memory available to it.
        Google SketchUp in our models ranging from 3mbs to 14mbs in file size still stutter and jolt.
        Further more the Laptop scored 4.7 out of 5 on the Vista Scoring system in Control Panel - so its a beasty Laptop with a crap graphics card????
        • AnssiA
          Anssi
          Compared to mine your models are quite big. If you use a lot of components, especially 3D trees and such, the actual face and edge count the computer has to handle may be huge.
          As the edges and faces are mostly handled by the CPU, your problem might not be with the graphics card, but with the processor speed. A dual-core Pentium is essentially two P IV processors on the same chip (with some enhancements). SU is not multithreaded, and it uses only one of these processors at a time, so the performance you can expect is only slightly better than from a 2 GHz Pentium IV of 3-4 years ago.
          Anssi
          • jujuJ
            juju
            I recently built a new machine (22" LCD/Intel Q6600/4GB RAM/ATi X1950GT 512MB/all the other regular stuff) that featured an ATi HD2600Pro 512MB at first. SU6 on the new machine with the HD2600Pro 512MB seemed slower than on my old machine (22"LCD/Intel PIV 3.4GHz/1GB RAM/ATi 9800Pro 128MB) so I bought the ATi X1950GT 512MB and tested it. The X1950GT 512MB was faster so I got rid of the HD2600Pro 512MB (donated it to a friend with a really old PCI-E GFX card in the end).
            To cut a long story short, I don't think the HD2600's have what it takes to run SU6 smoothly.
            • M
              mylos
              Hm...
              I have same problem like some of u. I have Intel C2D 2,6Ghz, 4Gb of memory and ATI Radeon 2900xt and 64-bit VISTA. And Sketchup work so slooooow that I think P1 is faster and not this super computer. I even disabled hardware acceleration and work only on CPU.
              Will be there 64-bit version and any new version which will be optimized for good graphic cards?
              regards
              Milos
              • J
                johnster
                SAME PROBLEM Here with my ATI HD2600... Cannot use hardware acceleration coz of selection bug....
                • P
                  ptz
                  Same problem with our new desktop computers with ATI Radeon HD 2400 XT. Sketchup is unusable with hardware acceleration on.
                  For what it's worth, Sketchup runs great on recently purchased laptop with nVidia card..
                  • R
                    rogalxxx
                    i have also some issues but with radeon 3850 :
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=3966
                    reported it to cards manufacturer.
                    if there's no solution to my problems, ill change my card for nvidia.
                    • D
                      danny
                      Hey guy,
                      I just builted a new rig with a ATI HD2900XT with 1Gb DDR4 clocked to 850Mhz core and 2150Mhz memory, and SU6 Pro is running pretty smooth so far. Using Catalyst 7.12 and in CCC (Catalyst Control Center) to reduce the jaggies I have these settings:
                      Standard Settings: "Use custom settings" box is Checked
                      Anti-Aliasing: "Level" set to 4X, "Filter" select Box
                      Anisotropic Filtering: "Pre-pixel sample" set to 8X
                      Catalyst A.I.: On the slider set to Advance
                      Mipmap Detail Level: On the slider set to Quality
                      I also still have "Use hardware acceleration" checked or ON. I think maybe with the 1Gb DDR4 memory and the slight overclocking must be a big help.
                      I hope this help you guys with ATI cards out there fight the jaggy eadges. πŸ˜‰
                      • I
                        innervito
                        Same Question!
                        does anybody can 100% solve this terrible question?
                        I have a ATI Mobility HD 2600, too
                        I will appreciate so much
                        πŸ‘
                        • broomstickB
                          broomstick
                          I think I have a solution for this (at least it is working for me so far)
                          I have recently got an imac 24 with the ati 2600 xt video card. Had I known the issue I wouldn't have gotten it but I didn't, at the time. So i did a bootcamp, and installe win xp Pro, then proceeded to install sketchup. Soon, I found out the glitches: the front face would never be selected, even if I checked the reverde face fix in preferences. I had a short deadline for a job, so I had to cope with it, befor finding a solution!
                          Tonight I had a look on the web and luckily for me the italian base came up with a solution:
                          they say that the Radeon 2600 architecture is very similar to the ATI MOBILITY FireGL V5600. Only problem you have to modify it to make it work on portable components.
                          So I downloaded the latest fireGL drivers from AMD/ATI site and then I got the mod tool, you can download it here:
                          http://www.driverheaven.net/modtool.php
                          Read carefully the instructions for the download of this tool, because you need some microsoft components in windows XP. It says that these are not necessary for Vista... I have tried this hack only in win Xp pro.
                          Once you have the two parts start the installation of firegl drivers. The program will decompress the files in a directory like c:/amd (but you can choose the location πŸ˜„ It will then start the installation, but tell you that he doesn't find any compatible hardware. It's ok, just cancel the installation.
                          Next, install the mod tool, and start the program. In the window of the program, search for c:/amd (or the folder where you extracted the files) and make him do the mod.
                          Now, simply restart the installation of the driver, clicking on the setup.exe file of the fireGl drivers. If everything is ok, installation will start, asking you to confirm the installation of non registered drivers. Let him do it's thing, and once you restart the system, the driver is good to go.
                          Now, when you open Sketchup, you should see that all the problems have gone. and the program runs as i should.
                          Tomorrow I'll give me a lot of SU love πŸ˜„
                          As usual your mileage may vary, and remember that these hacks are potentially dangerous for the system or the machine. Do a backup of your data and keep the original drivers handy, in the case something goes terribly wrong.
                          Ciao, from Napoli πŸ˜‰
                          • M
                            MikeR
                            sorry for ressurecting an old issue but i have the same problem....got an ASuS laptop and the same ATi H2600 Card....do we have a soultion for this in vista...dont want to downgrade in xp since i dont have an xp and dont have the budget to purchase at the moment...hope we already have a solution for this...thanks guys!!!
                            • broomstickB
                              broomstick
                              Unfortunately I tried this hack on a Vista machine and the result was none 😞
                              But, I'll have to retry on a clean machine...
