    Filleting and Chamfer edges
    18 Posts 13 Posters 25.3k Views 13 Watching
      dammerel
      Hi All..First time here !
      Like autocad / inventor can sketchup fillet and chamfer edge of solids?
      Andrew
        Hi Andrew - sure. Use the "Follow me" tool for this (you can search the forums - there are a bunch of topics about this here already).
          rsw
          This is something I've been wondering about aswell. I realise that I could use the follow me tool, but this doesn't really work for chamfering two curved surfaces such as the one shown below
          http://www.rsw3d.co.uk/sketchup/chamfer.jpg
          The shape above is easy to do manually but more complicated shapes aren't as easy (or quick) to do.
          Richard
            dammerel
            would you suggest seaching chamfer/fillet or follow me tool ?
            Andrew
              Andrew, the Follow me.
              I searched and there were 16 pages of posts - obviously a lot of them are in the same topics (so no 16 pages of topics... 😄)
              Richard, true, the follow me tool gets a little tricky when you want to extrude something out of one single plane - it twists and then it won't give you the desired result.
              Yet with a simpler "chamfering" you may try to do the sides separaetly and then intersect the resulting profiles.
              • boofredlayB Offline
                boofredlay
                dammerel, check out also the video tutorials.
                #9 is on the Follow Me tool.
                Error 404 (Not Found)!!1
                (sketchup.google.com)
                Cheers.
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi folks.
                  See attached SU file for ideas.
                  Chamfering.skp
                    rhankc
                    Nice lesson Jean, very clean, quick technique. thanks
                    Hank
                      Masta Squidge
                      I just typed out something more complicated than that tutorial but dang, i cant believe i didnt htink of using the follow me.. duh, senior moment.
                      • Y Offline
                        ypnos1
                        Agreed follow me can be used but....
                        there has to be a simpler way. If anybody has used or played with MOI 3d ( http://moi3d.com/ )you'll know what i'm talking about.
                        • Pick a line or number of lines
                        • fillet/chamfer tool
                        • specify distances and boom
                          you've got something wonderful
                        Wish it was this easy in SU
                        • N Offline
                          not registered yet
                          I think what Andrew wants is like that:
                          http://www.sketchucation.com/forums/scf/sas/Newbie/chamfer.jpg
                          Of course, he (and I) want to know how to make the cut accurately by specifying a distance. Also for fillet (by giving a radius).
                          Many thanks.
                          P: executor
                          • K Offline
                            kwistenbiebel
                            I very much agree with you Ypnos.
                            It should work like that and it would be a great tool to have, certainly towards photoreal rendering.
                            SU7?
                            By the way, happy birthday 😄
                            better late than never...
                            • jenujacobJ Offline
                              jenujacob
                              perhaps this might interest u???
                              chk the sixth item from the top!
                              http://www.ohyeahcad.com/download/index.php
                                boofredlay
                                Nice find. Does it work?
                                • K Offline
                                  kwistenbiebel
                                  thanks jenujacob...but it doesn't really work as described above.
                                  It only let's you draw boxes.
                                  I would like to be able to click-select edges of modeled objects so those can get chamfered.
                                    Masta Squidge
                                    I cant even get it to work, when i download it its just the .rbs file right? Where do i put that... I thought the plugins were .rb not rbs?
                                    • G Offline
                                      g2ktcf
                                      .rbs seems to be a compiled version of the plugin. This is how they keep the inner workings of the programs secure (read as $$$ making). I, for one, would like to see how they did it but i don't think it was that hard.
                                        Lukas92
                                        How about that?
                                        http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=9406K
