    Zooming then model disapears
    11 Posts 5 Posters 1.8k Views 5 Watching
    • syburnS
      syburn
      I have imported a simple acad plan. Then redrew over the plan to make a SU face (a few faces actualy).
      Now I want to start to model the walls etc but when I zoom into the window, the model sort of clips and disapears.
      I looked at the Model info and saw that it seemed very big, so i deleted the Cad layers which reduced line count from 14000 to about 152- but still clips and disapears when zooming.
      Any tips would calmm my stress in the office.
      LOBBY.skp
      P: syburn
      • R
        rhankc
        syburn,
        you seem to have some cad stray pieces in there somewhere, and you are at a very small scale.
        I would open a fresh SU file, window copy to clipboard a very tight box around your floor plan get just what is necessary from as close as possible: Past it to the new open file, and rescale the drawing. Use 1:1 size on your floor plan. If your copy paste reacts the same way in the new file, do it again a little differently, you probably grabbed the troublesome cad floater!
        hope this helps,
        Hank
        Hank
        • elmerE
          elmer
          Hi syburn,
          First erase the construction lines then if you do a "select all", you will notice a little line far from your model, erase it and everything will work fine;
          Hope that help,
          Regards,
          LOBBY.skp
          Patrice
          • elmerE
            elmer
            Woop, sorry i attached the wrong file, here comes the corrected one!
            LOBBY corrected.skp
            • D
              dylan
              That still clips Elmer.
              What Elmer says though is correct and is normally what may cause this. I just use Zoom Extents to see where the offending extras are.
              Another problem is you are so far away from 0,0.
              I also noice you have extra lines on your imported drawing which should not be there. It is also not on the ground plane.
              I would suggest making sure it is cleaned up corrctly before importing from ACAD.
              Try the Flatten command, Overkill, Purge and Audit.
              Make sure you import at correct units/scale also.
              Go back to acad, get rid of all the extra lines and text etc, place all remaining on 0 and run the commands I mentioned. Hopefully this may improve things.
              http://dmdarchitecture.co.uk/
              • ToboboT
                Tobobo
                I find that i have to import Cad files in mm or scale them up once imported. SU does have a small enough incrament for working in metres
                What i mean is 1 unit = 1 millimetre as apposed to 1 unit = 1 metre
                Hope i haven't confused you too much
                Toby
                Philippians 4:13
                • syburnS
                  syburn
                  I did draw to scale in mm, but when i imported it the dimensions all seemed wrong (so i used tape measure to change model scale).
                  Anyway i ll try all your tips now as see what happens.
                  P: syburn
                  • syburnS
                    syburn
                    What is the way to look/see find these stray cad pieces?
                    P: syburn
                    • R
                      rhankc
                      I say that because the dispaly all made your drawing very samll on the screen. I didnt see them, but elmer did, Your drawing was really unco-operative, so I opened a new session and copy/paste the plan to a new session and it corrected itself. You were right, about the tape measure, I work in imperial, but slect two points, tell the system what you want it to represent and select yes.
                      import your cad file to another file, it willcome in as a componenet, leave it as a component, if it disappears when you do a zoom extents your text, dimensions or something is messing with you. If it comes in ok trace over and around it and watch this video: Working with CAD:
                      http://www.go-2-school.com/podcasts/020
                      Hank
                      • elmerE
                        elmer
                        Here is an image to show where that little line is.
                        Patrice
                        http://www.sketchucation.com/forums/scf/sas/Newbie/Image-1.jpg
                        • syburnS
                          syburn
                          oh thanks everybody, i understand now and managed to import again from a block (im using autocad LT 2006 and seemed not to let me purge or overkill or flatten so a block seemed to work ok).
                          I have developed the whole thing now and I have posted it in the rendering gallery. Not so happy with it though.
                          P: syburn
