    Curved roads
    10 Posts 4 Posters 2.9k Views 4 Watching
    • N
      not registered yet
      i am trying to make a curved road....cud anyone pls help me...
      P: sdhamodaran
      • GaieusG
        Curved in which direction? Only on the x/y plane or winding uphill (on a TIN terrain) like a snake path?
        • jujuJ
          juju
          I think the best way to do this is to create a contour plan (showing indent/protrution a road will make in the contours) in a CAD package, save it as a DWG file, import into SU, layer the contours onto the various levels (depends on the contour increments used) and use the sandbox > from contours function to generate the terrain together with an approximation of the road all in one go.
          A good idea is to have a 2D (flat) line drawing of the road lined up in the Z-direction as well. Create a face from it, extrude it through the terrain generated above, intersect with model. You'll now be able to texture the road surface individually (and accurately) from the terrain model.
          • N
            not registered yet
            ya its part of a bridge whose one part is curved and tapering..
            P: sdhamodaran
            • KrisidiousK
              Krisidious
              SketchUp needs a Spline Command
              By: Kristoff Rand
              • GaieusG
                when you have the top view of the bridge as well as the surrounding, I'd suggest you to draw a 2d path for your road and then make a sloped drive of it down the bridge to the road it needs to connect.
                I've posted a "tut" about slanted ramps that you might make some use of during the process:
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=20&t=627
                If stuck anywhere, just come back...
                • N
                  not registered yet
                  hey thanks i used the arcs, offset and then push/pull then cut it into a neat bridge .. anyway i will try ur idea... then u can call me dam
                  P: sdhamodaran
                  • GaieusG
                    Only then? I mean Dam
                    πŸ˜„
                    • N
                      not registered yet
                      thats a gud one.. how abt a gtalk... i think it will be more useful atleast for me..
                      P: sdhamodaran
                      • GaieusG
                        Never tried...
                        msn?
                        sykpe (gaieus)?
