Problems with Materials/Textures
Okay, there is probably a simple solution to this problem but I have not found it. I am trying to paint planting bed with the pre-installed "ivy" material. However, all I see is a flat green color with no image. This is the case with all the material textures. It does not seem make a difference if I adjust the size. Is there a setting I'm not aware of?
jill
P: jillbot
Make sure you've set SketchUp (SU) to show the image in texture mode (button looks like a timber crate).
so simple!
Thank you. This did the trick.jill
P: jillbot
Register LoginAdvertisement
