    Problems with Materials/Textures
    3 Posts 2 Posters 904 Views 2 Watching
    • N Offline
      not registered yet
      Okay, there is probably a simple solution to this problem but I have not found it. I am trying to paint planting bed with the pre-installed "ivy" material. However, all I see is a flat green color with no image. This is the case with all the material textures. It does not seem make a difference if I adjust the size. Is there a setting I'm not aware of?
      jill
      P: jillbot
      • jujuJ Offline
        juju
        Make sure you've set SketchUp (SU) to show the image in texture mode (button looks like a timber crate).
        • N Offline
          not registered yet
          so simple!
          Thank you. This did the trick.
          jill
          P: jillbot
