    New: HouseBuilder metric 1.2 (customizable)
    44 Posts 14 Posters 19.3k Views 14 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      Juju requested a version of HouseBuilder to handle metric sections used in South Africa.
      I've just uploaded at the depositary a new version of the HouseBuilder package.
      Here it is: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1518
      This version 1.2 can load customized lumber sections from an external file, so everybody can input its own used sections. 😉
      Unzip in Plugins folder and please READ readme.txt ❗
      Have fun,
      DB
      • jujuJ
        juju
        hehe, one or two typo's in the txt file, but I think all is still clear enough. thx man.
        • Didier BurD
          Didier Bur
          Edited. Thanx for pointing out.
          DB
          • kmeadK
            kmead
            Good day Didier;
            I have run into a bit of a problem:
            Error Loading File HouseBuilder_extension.rb
            private method `split' called for nil:NilClass
            I run on Mac OSX so that may be some part of the issue. Is there something else I should have loaded?
            I created Dilbertville, sorry about that...
            • D
              Daniel S
              In my case i still cannot see the icons in the toolbar (like in previous versions of housebuilder)... It works well, but i can´t view the icons...
              • J
                Jan Vdb
                Hi, Didier
                Have the same problem as Daniel.
                Have clearly carried out the instructions of the readme file, but still can't see any icons.
                Work with a PC. (AMD Athlon 64 X2 Dual Core processor 4200+ /NVIDIA Geforce 7800 GT SLI)
                Thanks, Jan Vdb
                • Didier BurD
                  Didier Bur
                  Hi Kmead,
                  That's true, but my fault 😳
                  The text file "housebuilder_section.txt" is loaded from a path which is hard-coded and I suppose it is different on PC and Mac.
                  What the program does is that it searches the SU executable and it adds "Plugins/HouseBuilder" to the path
                  of the exe to find the text file.
                  What is the absolute path by default to the SU executable on a Mac ?
                  And what is the relative path of the HouseBuilder folder ?
                  Thanks for helping me to fix this problem.
                  DB
                  • Didier BurD
                    Didier Bur
                    Hi all,
                    I've released a new set of icons at the depositary (same post than the main prog).
                    Tell me if this one works for you 😒
                    Reagards,
                    DB
                    • EdsonE
                      Edson
                      didier,
                      sorry, but I could not find them.
                      edson
                      http://www.mahfuz.arq.br
                      • jujuJ
                        juju
                        emahfuz, go to the link in the post at the top of this thread, look for the attachment called hb_icons.zip and download. Next find your SU installation folder, go to plugins > housebuilder folder, copy icons extracted from the zip file provided into said folder. 😉
                        • J
                          Jan Vdb
                          Hi, Didier
                          Sorry to say that the new icons don't make any difference
                          Greetings, Jan Vdb
                          • D
                            Daniel S
                            Hi Didier,
                            I install the new icons but still no lucky...
                            i´m runing SU in PC with windows (but spanish version, maybe that´s the problem)
                            The absolute path by default to the SU executable is:
                            C:\Archivos de programa\Google\Google SketchUp 6\SketchUp.exe
                            I think that everyone has "Program Files" instead "Archivos de programa"
                            Daniel S
                            • Didier BurD
                              Didier Bur
                              What's going on with these icons
                              Still searching.
                              Anyone has my layer manager script with similar problems ???
                              DB
                              • kmeadK
                                kmead
                                Didier:
                                On a Mac the path will always be:
                                /Library/Application Support/Google Sketchup 6/Plugins/Housebuilder/housebuilder_sections.txt
                                if that helps.
                                Many thanks, I haven't been by earlier so my apologies for taking so long to post the info.
                                I was looking at the old housebuilder and the ruby wasn't encoded like it is now or I would have tried chasing this myself.
                                Many thanks and have a great day.
                                Karl
                                • jujuJ
                                  juju
                                  I've installed ruby as directed, activated the housebuilder menu under the view functions, also replaced the images with the new - still no icons though...
                                  • Didier BurD
                                    Didier Bur
                                    SORRY all for the inconvenience (related to icons) 😳
                                    I think I've got the solution: for an unknown reason scrambled extension code doesn't seem to work OK on some platforms (wether PC or Mac).
                                    I'll publish in a few hours a "non-scrambled" main script to replace the 'offender'.
                                    Regards,
                                    DB
                                    • Didier BurD
                                      Didier Bur
                                      💭 I'm sure this one will work !!!
                                      Please download it at the depositary and re-install ALL files.
                                      Regards,
                                      DB
                                      • D
                                        Daniel S
                                        Now I can see the icons!!!
                                        Thank you Didier!!! 😄
                                        Daniel S
                                        • A
                                          azuby
                                          Didier, some hint for the encrypted/scrambled version: The code is executed through "eval" and so some file infos are missed. If you want to build a nearly fully encrypted version, you can write a simple non-encrypted Ruby file, which only sets a global constant (make sure you are not using a variable) like
                                          MY_FILEDIR = File.dirname(__FILE__).gsub(/[\\\/]/, File;;SEPARATOR) << File;;SEPARATOR unless defined? MY_FILEDIR # all in one line
                                          Within the encrypted file you -> require the non-encrypted file and are done. Say you have
                                          • my.rbs
                                          • my/mypath.rb
                                            than you require like this:
                                          require 'my/mypath.rb'
                                          The "defined?"-thing is done to avoid possible redefiniton of the constant - that would raise an error (or give a warning, not sure).
                                          edit: One regular expression and one gsub is enough 😉
                                          azuby
                                          • kmeadK
                                            kmead
                                            Didier:
                                            I still get:
                                            When SU starts and although one can bring up the House Builder tool pallette, it won't actually do anything when one clicks on the buttons.
                                            Sorry for being a wet blanket
                                            Karl
                                            • 2 / 3
