    New: HouseBuilder metric 1.2 (customizable)
    44 Posts 14 Posters 18.0k Views 14 Watching
      Didier Bur
      Hi all,
      Juju requested a version of HouseBuilder to handle metric sections used in South Africa.
      I've just uploaded at the depositary a new version of the HouseBuilder package.
      Here it is: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1518
      This version 1.2 can load customized lumber sections from an external file, so everybody can input its own used sections. 😉
      Unzip in Plugins folder and please READ readme.txt ❗
      Have fun,
      DB
        juju
        hehe, one or two typo's in the txt file, but I think all is still clear enough. thx man.
          Didier Bur
          Edited. Thanx for pointing out.
          DB
          • K Offline
            kmead
            Good day Didier;
            I have run into a bit of a problem:
            Error Loading File HouseBuilder_extension.rb
            private method `split' called for nil:NilClass
            I run on Mac OSX so that may be some part of the issue. Is there something else I should have loaded?
            I created Dilbertville, sorry about that...
              Daniel S
              In my case i still cannot see the icons in the toolbar (like in previous versions of housebuilder)... It works well, but i can´t view the icons...
                Jan Vdb
                Hi, Didier
                Have the same problem as Daniel.
                Have clearly carried out the instructions of the readme file, but still can't see any icons.
                Work with a PC. (AMD Athlon 64 X2 Dual Core processor 4200+ /NVIDIA Geforce 7800 GT SLI)
                Thanks, Jan Vdb
                  Didier Bur
                  Hi Kmead,
                  That's true, but my fault 😳
                  The text file "housebuilder_section.txt" is loaded from a path which is hard-coded and I suppose it is different on PC and Mac.
                  What the program does is that it searches the SU executable and it adds "Plugins/HouseBuilder" to the path
                  of the exe to find the text file.
                  What is the absolute path by default to the SU executable on a Mac ?
                  And what is the relative path of the HouseBuilder folder ?
                  Thanks for helping me to fix this problem.
                  DB
                    Didier Bur
                    Hi all,
                    I've released a new set of icons at the depositary (same post than the main prog).
                    Tell me if this one works for you 😒
                    Reagards,
                    DB
                    • EdsonE Offline
                      Edson
                      didier,
                      sorry, but I could not find them.
                      edson
                      http://www.mahfuz.arq.br
                        juju
                        emahfuz, go to the link in the post at the top of this thread, look for the attachment called hb_icons.zip and download. Next find your SU installation folder, go to plugins > housebuilder folder, copy icons extracted from the zip file provided into said folder. 😉
                          Jan Vdb
                          Hi, Didier
                          Sorry to say that the new icons don't make any difference
                          Greetings, Jan Vdb
                            Daniel S
                            Hi Didier,
                            I install the new icons but still no lucky...
                            i´m runing SU in PC with windows (but spanish version, maybe that´s the problem)
                            The absolute path by default to the SU executable is:
                            C:\Archivos de programa\Google\Google SketchUp 6\SketchUp.exe
                            I think that everyone has "Program Files" instead "Archivos de programa"
                            Daniel S
                              Didier Bur
                              What's going on with these icons
                              Still searching.
                              Anyone has my layer manager script with similar problems ???
                              DB
                              • K Offline
                                kmead
                                Didier:
                                On a Mac the path will always be:
                                /Library/Application Support/Google Sketchup 6/Plugins/Housebuilder/housebuilder_sections.txt
                                if that helps.
                                Many thanks, I haven't been by earlier so my apologies for taking so long to post the info.
                                I was looking at the old housebuilder and the ruby wasn't encoded like it is now or I would have tried chasing this myself.
                                Many thanks and have a great day.
                                Karl
                                  juju
                                  I've installed ruby as directed, activated the housebuilder menu under the view functions, also replaced the images with the new - still no icons though...
                                    Didier Bur
                                    SORRY all for the inconvenience (related to icons) 😳
                                    I think I've got the solution: for an unknown reason scrambled extension code doesn't seem to work OK on some platforms (wether PC or Mac).
                                    I'll publish in a few hours a "non-scrambled" main script to replace the 'offender'.
                                    Regards,
                                    DB
                                      Didier Bur
                                      💭 I'm sure this one will work !!!
                                      Please download it at the depositary and re-install ALL files.
                                      Regards,
                                      DB
                                        Daniel S
                                        Now I can see the icons!!!
                                        Thank you Didier!!! 😄
                                        Daniel S
                                          azuby
                                          Didier, some hint for the encrypted/scrambled version: The code is executed through "eval" and so some file infos are missed. If you want to build a nearly fully encrypted version, you can write a simple non-encrypted Ruby file, which only sets a global constant (make sure you are not using a variable) like
                                          MY_FILEDIR = File.dirname(__FILE__).gsub(/[\\\/]/, File;;SEPARATOR) << File;;SEPARATOR unless defined? MY_FILEDIR # all in one line
                                          Within the encrypted file you -> require the non-encrypted file and are done. Say you have
                                          • my.rbs
                                          • my/mypath.rb
                                            than you require like this:
                                          require 'my/mypath.rb'
                                          The "defined?"-thing is done to avoid possible redefiniton of the constant - that would raise an error (or give a warning, not sure).
                                          edit: One regular expression and one gsub is enough 😉
                                          azuby
                                          • K Offline
                                            kmead
                                            Didier:
                                            I still get:
                                            When SU starts and although one can bring up the House Builder tool pallette, it won't actually do anything when one clicks on the buttons.
                                            Sorry for being a wet blanket
                                            Karl
                                            • 1 / 3
