    [Plugin] ExtrudelineTool Update
    72 Posts 28 Posters 85.9k Views 28 Watching
      @monmonred said:
      a sketchup 2014 update for this pleeeeease! πŸ˜„ thanks in advance!
      As I have said in some other threads for to Didier's 'packed' plugins...
      Edit the plugin's .rb file using Notepad.
      At the end of the code it says:
      .unpack("m")**.to_s**
      change the end part to read
      .unpack("m")**[0]**
      Save and restart SketchUp...
      It should now work fine in any SketchUp version.
        Didier has agreed that I might update some of his Plugins in the PluginStore.
        Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=extrudelinetool-Modified-TIG This is v2014/2015 compatible.
        • P Offline
          Pherim
          Sketchup 2015 64bit sometimes freezes when I use this.
            Ruby Console errors ?
            It IS an old script - there are now better solutions.
            I updated it for Didier, only for completeness... πŸ˜•
              @pherim said:
              No, it just doesn't react any more. This seems to happen particularly if the start point is set not on the selected line, but also sometimes if it is.
              Can you recommend an alternative?
              My Extrusion toolset http://sketchucation.com/pluginstore?pln=ExtrudeTools
              • P Offline
                Pherim
                • P Offline
                  Pherim
                  Great, thanks! I already had that installed but I must admit I have never really taken a closer look at it, although your plugins are always top notch.
                  • josephkim626J Offline
                    josephkim626
                    Just to note,
                    This extension no longer generates face in 2017 version.
                    I suppose it is just not being updated.
                      This a previously reported issue.
                      It is being updated for v2017 compatibility... just that I haven't finished it yet !
                      The way v2017 handles references and IDs changed and broke some of the EEby tools...
                      I have most of them fixed - just tweaking the last few...
                      There is actually a separate thread discussing this too...
                        josephkim626
                        Ah, sorry. I wasn't aware that there is another thread.
                        Thanks for all the work TIG!
                          lapx
                          Thanks Tig! I am having same issue with extruding a line to face also.
                          • boofredlayB Offline
                            boofredlay
                            TIG, any chance you can put this on the front burner? This is one tool I use(d) very frequently and I am missing it.
                            Thanks.
                              97% updated...
                              I have to earn a crust too...
                                Extrude line(s) is maybe the more useful tool in case of headache's situation!
                                And of course with the new Quads world of SUbD ! πŸ€“
                                (works yet fine in 2015, 2016! πŸ˜‰
                                  boofredlay
                                  Thanks for the update on the update TIG. I appreciate what you do.
                                    I've updated this oldie for v2017 compatibility.
                                    https://sketchucation.com/pluginstore?pln=extrudelinetool-Modified-TIG
                                    • G Offline
                                      greatoe
                                      sorry but this won't work on a Mac
                                        Works fine in PC! πŸ˜„
                                        Seems Projections by Didier Bur / Tig works fine also! πŸ˜„
                                        • pbacotP Offline
                                          Thanks TIG! I haven't tried this one, though I have used extrude Tools and other plugins this way.
                                            Please explain your issues...
                                            How does it 'not work' ?
                                            Does it install ?
                                            Does it load ?
                                            Is there a menu item ?
                                            What happens when you use it ?
                                            Any error messages in the Ruby Console ?
                                            I see no reason that this should not work on a MAC...
                                            The minor recoding was done because v2017 now references / handles some entity explosion results differently...
                                            • 3 / 4
