    [Plugin] Exporting a texture from a material
    29 Posts 15 Posters 39.5k Views 15 Watching
    • eidam655E Offline
      eidam655
      thanks for the fix, but in the meantime i also found the plugin TIG linked, so it's settled...
      i might download the new version of this plugin, just to see the difference in source code; might come handy 😄
      I'm using SketchUp 2017, V-Ray 3.4
      • dramachik27D Offline
        dramachik27
        Hello, I am new to sketchup and I am trying to use the program to create 3D models for a game. The issue I am having is when I export the model into Torque. We see all the colors I have applied but as for textures, they are all gone. Is there a way to change this outcome? 😄
        ~G
          What format are you exporting to?
          • deaneauD Offline
            deaneau
            hi Al Hart, i would love if you change your plugin by reading the color name and than naming the textures. this would be cool
            thank you
            MADE, BORN AND LIVING IN BERLIN
            Big Thank You to all Programmers
            Some German words are so long that they have a perspective. M.Twain
            • Al HartA Offline
              Al Hart
              Would you like to rename color only materials in SketchUp (not materials with textures) so the name matches the color (eg. RGB 255,0,0 becomes red), for common colors and the hex color for non-standard colors (e.g. RGB 100,200,100 becomes #64c864)
              One "problem" we found recently is that people don't call RGB 0,255,0 green - but rather call it lime- and call 0,128,0 green
              as in this chart:
              https://s-media-cache-ak0.pinimg.com/236x/f9/47/82/f94782af2fff3cdb9bef53556d989852.jpg
              Al Hart
              IRender nXt from Render Plus
              • Al HartA Offline
                Al Hart
                or did you mean that you wanted to rename the material itself to match the texture name included in the material?
                Al Hart
                • Al HartA Offline
                  Al Hart
                  or did you want to automatically rename the textures stored in the material to match the name of the material itself.
                  This gets tricky because the SketchUp material can have names like: a'b/c, while a'b/c would not be a legal name for the texture itself.
                  Al Hart
                  • deaneauD Offline
                    deaneau
                    Al sorry for my very late answer.
                    1. about Lime RGB 0 255 0
                    in the RAL Colorchart you have not a color with this Name and RGB value.
                    look here
                    http://www.ralcolor.com
                    standard colors Like RAL, HKS, PANTONE etc. is based on the subtractive color scheme (body colors) when you have "RGB" (normally additive color scheme) and add al three together you have black as result.
                    additive color scheme https://de.wikipedia.org/wiki/Additive_Farbmischung
                    result is white (light colors)
                    the RGB Value is only an orientation and the name of the color is an orientation ,too. some peoples can memorize names better than digits or numbers and vice versa.
                    1. i would have this:
                    at (1) this name as image name, too in field (2)
                    actually the plugin doesn´t work with the last sketchup make, or i doing anithing wrong.
                    i have attache the skp file.. the object was created with eneroth extract material.
                    the color itself was created with a CSV-import-plugin.
                    sorry again for the late answer.
                    best regards Dean
                    RAL_TEST_Sketchucation.skp
                      ChokDK
                      Hi writers and devs in this thread.
                      Just 4 years later I found this! 😄
                      I am looking for an exporter that can export (to .png) "whatever" colors or material used in SketchUp into 1 file, and so that it can be used in an OBJ file.
                      In fact, something similar to what Blender can do ( Blender call it "bake" or "baking")
                      is this possible, does something similar already exist, or.. would someone do it? 😄
                      Regards
                      • 2 / 2
