    [Tutorial] Removing stray Edges on import
    3 Posts 3 Posters 3.5k Views 3 Watching
    • jim smithJ
      jim smith
      THANK YOU for the tut . I import a lot of dxf dwg drawings and have wasted quite a bit of time trying to clean them up, this will be a major speed-up
      "Out of clutter find simplicity,
      from discord find harmony,
      In the middle of difficulty lies opportunity"
      Albert Einstein
      • A
        Antoino6911
        Coen,
        How do I select just the lines I should and not the hiden ones?,
        Rgds.
        • GaieusG
          Antonio,
          If you have hidden lines (view menu) turned off and you select the geometry by the selection box (not triple clicking), you cannot make a mistake; only visible ("not hidden") lines will be selected in wireframe mode.
