    [Tutorial] Removing stray Edges on import
    3 Posts 3 Posters 3.4k Views 3 Watching
    • jim smithJ Offline
      jim smith
      THANK YOU for the tut . I import a lot of dxf dwg drawings and have wasted quite a bit of time trying to clean them up, this will be a major speed-up
      "Out of clutter find simplicity,
      from discord find harmony,
      In the middle of difficulty lies opportunity"
      Albert Einstein
        Antoino6911
        Coen,
        How do I select just the lines I should and not the hiden ones?,
        Rgds.
          Antonio,
          If you have hidden lines (view menu) turned off and you select the geometry by the selection box (not triple clicking), you cannot make a mistake; only visible ("not hidden") lines will be selected in wireframe mode.
          With your input, this post could be even better šŸ’—
