    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Tutorial > Modeling] Arch in a curved wall.
    32 Posts 14 Posters 12.1k Views 14 Watching
    • boofredlayB Offline
      boofredlay
      @julius said:
      very useful tutorial, but...how did you stitch together in scene 11?
      Basically I just drew points from each endpoint to another, triangulating the surfaces until they "Fill In". Nothing automated there, just drawing.
        Julius
        ok, so you drew lines, thank you!
          Julius,
          You can also use Darrel's "Skin.rb" plugin for this.
          Marc,
          Whenever you encounter such a problem (the PP tool not intending to push further), you can group any of the entities (either what you want to push or the one you want to push trough) and you can do the operation. Then you can just simply explode the group.
            Julius
            wow, great script! thanks gaieus and thanks darrel!
              trillium
              hi Gaieus, when you have time would you post a tutorial or quick steps list to show us how you did this one? it's beautiful!!
                Well, to tell the truth, I'm no longer sure how exactly it was modelled but what I'm sure about is that I'd definitely do it somehow else now.
                I remember suffering a lot with it (back then when I also have just started using SU) but now we have so many useful plugins that would make life easier that. Anyway, here's the model if you're interested (last year I re-uploaded it to the WH when we were going to test some new features there).
                Surely it would be worth a tutorial although it would probably be a bit lengthy. ๐Ÿ˜‰
                • charly2008C Offline
                  charly2008
                  Hi Scaba,
                  a like such models. I tried also to construct such details but i was not so successfull like you.
                  Karlheinz
                    You always have to take into consideration that those SU surfaces though look curved, are actually faceted and then adjust your "mini galleries" (or what they're called) that way. Made from straight segments. I'm sure however that if you download my model, you'll find lots of mistakes in it (as I'm sure there are as as I said,it was a very early challenge for me, too). ๐Ÿ˜‰
                      trillium
                      thank you so much Gaieus, i got it!!!! and some of your other great models in the warehouse โ˜€
                      i guess my main question is very similiar to Karl's - how to create push/pull kind of details and cuts on curved surfaces, plugins? or intersect?
                        I'm really serious when saying that I can't remember. Nowadays it would be "easy" with Joint Push Pull and Tools on Surface plugins (both by Fredo) or Shape Bender (by Chris) but back then they didn't exist. It could be done by intersecting however. I'd need to put together a little tutorial for that but I have to tell the truth, I'm a bit behind my schedule. I'll do it anyway.
                        BTW I "pulled down" most of my models from the WH once I got pissed off some guys there... ๐Ÿ˜’
                        Only left those which I made for others (mainly).
                          sepo
                          My first thought was Shape Bender. It should be quite easy.
                          • david_hD Offline
                            david_h
                            Done in about 1 minute with BoolTools, JPP, and Tools on Surf.
                            Pretty fun.
                            • 2 / 2
