    Exporting to ACAD...lost lines
    7 Posts 5 Posters 2.1k Views 5 Watching
    • M
      maalox
      SU 6, Win XP
      Draw model, set to 2 point perspective, hidden line mode, export 2d graphic, select .dwg file type, export.
      Open in Autocad and several lines are missing: roof edges, column edges, etc.
      Is there a "fix" for this?
      thanks,
      poster-maalox
      • J
        JuanV.Soler
        post the file ?
        • M
          maalox
          The file is 1128 kb. From what I can tell that seems to be over the allowable file size limit.
          m
          poster-maalox
          • KrisidiousK
            Krisidious
            the only fix I have found is exporting in AutoCAD R14 mode
            By: Kristoff Rand
            • AnssiA
              Anssi
              This has been happening for as long as I have been using SU. For some reason the EPS/PDF export has IMO less missing lines. This might be paradoxically due to it being more inaccurate...
              On the other hand, the hidden-line algorithms of other apps do not seem to be too accurate either. I have seen the same happen when doing hidden-line plots from AutoCad too.
              Anssi
              • M
                maalox
                Thank-you all for taking the time to post a reply.
                I tried the ACAD R14 export, and I tried saving to SU5 then exporting to ACAD R14 out of SU5, a little better but still lines were lost. I don't mind adding them back it's just suddenly noticing another one that was missed after it's all been plotted out. Arrrgh!
                Very nice looking forum by the way.
                m
                poster-maalox
                • E
                  Ekon
                  I'm on SU 2013. Still the same problem. Only wireframe mode exports 2d accurately, but then, working my exported sections to delete all hidden lines feels like a deal breaker. Any new light on this issue?
