    Red X over Viewport
    layout
    4 Posts 3 Posters 8.7k Views 3 Watching
    • R
      rhankc
      Layout is blanking out on me. The view port is opaqueing over and getting a red x from corner to corner of the viewport. I first thought it was because i had doubled up on the same viewport being open twice; but that wasnt it. After reboot I had satisfactory results for about 30 min of zooming rotating panning etc before it happened again.
      any thoughts?
      TIA
      Hank
      Hank
      • jujuJ
        juju
        I've also had this happen to me quite a few times in the past. What I do is to import the selected view again. I set up my views in SU and then use them in LO.
        • B
          bjanzen
          It's a memory issue... you can avoid this during setup by changing your model dpi to your screen dpi (usually 96 on XP, 72 on Mac OS X). Only render at higher dpi's when you're ready to print. We are working on (a) more description to what's happening when the red x appears and (b) dealing with memory in a better fashion.
          (bjanzen)
          • R
            rhankc
            thanks guyd. zi fo hsvr thr dpi turnrd high. I'll let it down and give it shot. Talk to you soon.
            Hank
